sea foam treatment - Ford Truck Enthusiasts Forums
sea foam treatment
Old 06-10-2010, 01:13 PM
firefighter1416's Avatar
firefighter1416 firefighter1416 is offline
firefighter1416 is starting off with a positive reputation.
sea foam treatment
so thinking of giving my old 96 4.9 the sea foam treatment, anyone got any suggestions and so forth? you just run it in that line going from the brake booster to the intake right? Its just running doggy as crap with the a/c on and was hoping to get a little more power! Also what would be a good indicater that the cats are plugged? 132000 miles
Old 06-10-2010, 03:02 PM
rockin300's Avatar
rockin300 rockin300 is offline
rockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud of
if your cat is pluged the cat would be a red/brown color and the manifolds would be that red/brown color as well what kind of seafoam do you have the spray can or the bottle
Old 06-10-2010, 03:32 PM
ymeski56's Avatar
ymeski56 ymeski56 is offline
Der Postmeister
ymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputation
Old 06-10-2010, 06:39 PM
rockin 300, im gonna use the can type, thanks for the replys!
Old 06-10-2010, 10:02 PM
pintoches's Avatar
pintoches pintoches is offline
pintoches has a good reputation on FTE.pintoches has a good reputation on FTE.
Oreillys Has Sea foam buy 2 get one free!
Old 06-11-2010, 09:13 AM
greg213187's Avatar
greg213187 greg213187 is offline
greg213187 is starting off with a positive reputation.
My truck is running fine however it has 197000 miles on it. Would anyone recommend using seafoam on it anyway?
Old 06-11-2010, 09:35 AM
ymeski56's Avatar
Der Postmeister
Quote:
No reason not to. It just detoxes / desludges the engine. I would do it prior to every oil change 1/3,1/3,1/3 & run lucas injection cleaner in gas every 4-5 tanks.Sea Foam | Motor Treatment
Old 06-11-2010, 06:24 PM
well did the the treatment today all went well can't tell if it helped or not couldn't have hurt. Still runs like crap just doggy as crap seems like it has a rev limitor on it. Runs about 211F cleaned the maf sensor changed rotor cap, and rotor they were pretty crappy im outa ideas?
Old 06-11-2010, 07:38 PM
08kingranchAZ 08kingranchAZ is offline
08kingranchAZ is starting off with a positive reputation.
my brother said that stuff works pretty good
Old 06-11-2010, 09:30 PM
93MARKIII's Avatar
93MARKIII 93MARKIII is offline
93MARKIII is starting off with a positive reputation.
lol, just make sure your truck is outside !!.....
Old 06-11-2010, 09:32 PM
93MARKIII's Avatar
Quote:
first time ive heard this....is it an accurate rule of thumb ? cause my stuff is reddish brown
Old 06-12-2010, 07:10 AM
ymeski56's Avatar
Der Postmeister
Quote:
You can temporarily remove the 02 sensor ahead of the cat to see if power returns, or take a pressure read at the bung hole. Should be less than 3psi. Or take to muffler shop & have checked. Habitual use of higher than 87 octane will poison & clog a Cat. If replacement is required 7 you have two inline, replace w/ a single hi-capacity unit.
Old 06-12-2010, 07:16 AM
ymeski56's Avatar
Der Postmeister
Quote:
Ignition upgrade to stretch plug gap, then further advance timing. FullSizeBronco.com - 78 - 96 Ford Bronco offroad club, forums, tech, installs & About the Ign. sys./timing bump. - Ford F150 Forum - Community of Ford Truck Fans Check out your Cats first.
Old 06-12-2010, 08:09 AM
DBGrif91's Avatar
DBGrif91 DBGrif91 is offline
DBGrif91 is gaining momentum as a positive member of FTE.DBGrif91 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by ymeski56 View Post
...bung hole...
You may need some T.P. for that...
Sea Foam rews2 1967 - 1972 F-100 & Larger F-Series Trucks 11 06-09-2014 11:10 AM
Sea Foam,V10 holyshift 1999 to 2016 Super Duty 8 07-18-2013 02:58 AM
V10 PCV valve/sea foam? jleo 1999 to 2016 Super Duty 24 01-05-2013 02:37 PM
Sea Foam Motor Treatment mtntop1 Aftermarket Products 11 06-11-2009 03:08 PM
Lucas & Sea Foam Fuel treatment Gage2502 1999 to 2016 Super Duty 5 01-06-2008 10:20 PM
Tags
1993, 49, 96, bronco, des, e4od, f150, foam, foraming, ford, forum, moines, sea, seafoam, treatment, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
