22" on 2010 F250 FX4 CC SWB
here is my question I have a 2010 F250 CC SWB Fx4 6.4 The truck came with the 20" factory wheels and I have a set of 22" wheels that I purchased for it.. I wanted to know if the 325 50 22 tires will work with it NOT lifted or will I need a LEVEL kit for the front end? DO they make E Rated tires that are a little bit smaller and not as wide?
I have a feeling they will rub as there is not much clearance with the factory 20's in there, but I know someone else will be able to tell you for sure. Best advice I got when thinking about upgrading my rims was to watch the weight ratings on the aftermarket rims, most are VERY low. So you'll end up with a truck that looks good but can only tow 2000lbs. Not a big deal if your driving a pavement princess but something to seriously consider if you plan on loading or towing anything heavy down the road.
I would say it really depends on the offset of these new wheels. The new tires are only about .3 inches more in OAD than the stock 20's... however they are they are almost 2 inches wider I believe. That combination with a more aggressive offset and those things will rub! Also, your ride is going to be super stiff! I would avoid 22's unless you are going to run a 7" lift running 37" tires. That is just my opinion though, some guys don't mind riding on concrete.
hivewax
16
05-02-2012 03:12 PM
