1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Door Lock Tumbler Assembly
Old 06-09-2010, 08:22 PM
Deluxe06's Avatar
Deluxe06
Deluxe06 is offline
4000 rounds a min
OK guys bare with me this is my first post. The other day my driver side door lock quit turning so I went out and bought a new one. I know i could have just shot some lube or something in there but i was concerned about the ware on my key. Didn't now if any of the tumblers were worn out or not. This is the way i went about it.
First i removed the inner door panel.
Then the little black plug.
Witch reveled one of the door handle nuts. Remove this nut (11mm 1/4" drive socket)
down and to the right is the other nut tucked in behind the window track. remove this nut (11mm wrench)
Door handle removed reveling lever rods.
Find and remove E clip that holds the lever on the tumbler assembly.
Now remove the spring clip that holds the tumbler in place.
The tumbler assembly will slide out from the back.
install new tumbler assembly and then spring clip.(for ease of spring clip install i went ahead and removed handle from the other rod)
Reinstall lever on the tumbler assembly.
put lever rods back in place.
Put door handle back on door and test with a key.
Reinstall door panel and your done.
Hope this helps anybody that needs to do this
Deluxe06
Old 06-10-2010, 12:07 AM
wallz's Avatar
wallz
wallz is offline
Good detail with pictures. Rep given.
Old 05-27-2011, 05:32 PM
fbh31118's Avatar
fbh31118
fbh31118 is offline
Great write up! Were you able to order the tumbler to match your current ignition key?
divedeep1
05-04-2010 01:47 PM
Brown Falcon
07-12-2009 08:50 AM
460429_freak
Missouri Chapter
05-14-2009 01:56 PM
ExcursionMan
06-17-2008 03:03 PM
i eat hybrids
01-12-2008 07:07 PM
Quick Reply: Door Lock Tumbler Assembly
