'05 F150 5.4 DTC P2004 won't go away - Ford Truck Enthusiasts Forums
Old 06-09-2010, 09:17 PM
high_idle high_idle is offline
high_idle is starting off with a positive reputation.
Nice forum you have here. With lots of info but i haven't seen an answer to my problem with all of my searching efforts so i am forced to ask for some help.
I've got an '05 F150 with the 5.4 and a P2004 code that won't go away. I have taken the intake off and cleaned all the runners and plates, and made sure they are moving properly. Both rods are connected and the bushings are fine but the code still comes back. The part that makes the least sense is there is no possible way for one side to stick open and not the other unless the rod falls off when it is in the open position, which isn't the case.
The only thing I can think of that makes any sense is the motor tells the PCM when it has them open or closed and it thinks the right side is stuck open. Does anybody know if the control motor has sensors inside it that sense when they are open or closed? The intake itself doesn't have any switches in it or on it to sense their operation or position.
All ideas are welcome since I am at a total loss on this and the dealer won't talk to me about it with out being paid for it.
Thanks
high_idle
Old 06-18-2010, 12:56 PM
FordMasterTek FordMasterTek is offline
FordMasterTek is starting off with a positive reputation.
your problem is the imcr controller remove the intake and replace the controller the parts $60 at the dealer FOLLOW the directions to the T if you don't damage to the new controller will result..
You can watch the operation of the controller with a mirror have someone in the truck snap the thottle over 3k rpms and you watch the rods they should rotate clockwise and return to closed postion..
Ford Techs: 5 DTC codes, all TPS related... Biker1966 2004 - 2008 F150 14 12-04-2015 03:20 AM
door locks jwiowa 1999 to 2016 Super Duty 0 08-09-2014 05:26 PM
High-Idle Mod maverick1701 Modular V8 (4.6L, 5.4L) 9 04-15-2013 03:11 PM
Coolant Flush Notes - with pics bpounds 6.0L Power Stroke Diesel 13 07-28-2010 08:57 PM
EEC Self Test Codes - What Do I have Here?? EHC112 1987 - 1996 F150 & Larger F-Series Trucks 11 08-25-2009 01:25 PM
Tags
04, 05, 2004, 2005, 2006, 54, code, dtc, dtcs, engine, f150, fault, ford, p2004, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
