2001 F150 4.6 EGR Problem - Ford Truck Enthusiasts Forums
Old 06-09-2010, 08:00 PM
sjjs01 sjjs01 is offline
sjjs01 is starting off with a positive reputation.
Brand new and my first post. My son has a 2001 Ford F150 4.6. We changed the FDPE sensor around this time last year and it took care of the fuel dumping problem at the time. About a week ago the truck started using gas like crazy and the EGR light coded insufficient flow. We changed the FDPE sensor again but this time there is no change and it is still coding insufficient flow. Any help would be appreciated. Thanks
Old 06-09-2010, 08:45 PM
Dialtone Dialtone is offline
Dialtone is gaining momentum as a positive member of FTE.
Test the EGR valve by applying a vacuum soruce directly to the egr valve port.
At idle, engine should run rough or die if egr is flowing exhaust gas properly.
If not, remove throttle body and check for blocked egr gas passage behind it. It will probably be caked solid with carbon.
Clean it out, reassemble and retest.
If it really is running rich, this is source of the excess carbon buildup and needs to be fixed also, but that is another story.
Old 06-09-2010, 10:44 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
There has been a lot of replies about this code, so a search would net you all there is about the fault.
The code is the failure report on "one" test the computer does on the EGR system.
The DPFE is not always the problem.
It's a flow test set up by the computer so the DPFE can see the results and report to the computer.
The total passage, the EGR and all hardware involved, any of which will cause a failure if any part/s fails.
Simple testing wil tell you what is the most likely fault.
The DPFE is the last item when all other tests are good.
I only told you half of it.
Dig out the testing and see what you have.
Good luck.
Old 06-09-2010, 10:51 PM
Thanks for your help
Thanks for the information. I sounds to me like I need to do some carbon cleaning.
Code P0401 -- EGR insufficient flow, 1997 F150, 4.6L Al_Cuevas 1997 - 2003 F150 93 08-13-2016 09:50 AM
1998 Expedition Diagnostic code P0401 Insufficient EGR Flow JarrettCox Expedition & Navigator 21 02-20-2016 09:24 PM
Egr insufficient flow valve tick 99F250fx4v10 Modular V10 (6.8l) 3 11-13-2011 12:09 PM
code p401 inssuficient egr flow help treehugger1 1997 - 2003 F150 4 09-04-2010 10:10 AM
'97 F150 4.6l misfiring on #4 cylinder/egr insufficient flow joe32hog 1997 - 2003 F150 6 01-28-2002 09:58 PM
Tags
1997, 2001, 2001f150, 2003, 46, applying, code, dies, egr, f150, ford, gas, problems, replacement, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
