I need the shroud for my 54 F-100 with a 6 cyl. that is original. I think the 55 with 6 cyl is the same. I am looking for original as i am restoring the truck.
morobreath
Did you need it because of temperature control?
To a certain extent, yes.
I was breaking in the cam and so the truck wouldn't be moving, however, it'd be at a high rpm. So I thought it might want to overheat, so I put a shroud to see if it'd help.
However, it's been there since I got the truck running, so I don't honestly know if it would've ran any differently(hotter) without it. I just did it for good measure.
Yeah, for some reason Ford didn't have shrouds available for I-6 models.....Don't really get it.
I made my own out of sheet metal and some screws. Took me about 20 minutes.
Ford did make fan shrouds for the sixes. My 52 has one that was original. Also the part number for the 53-55 I6 shroud is TAAA 8146-A. This was for the 215 and 223. Good luck finding one, but I am sure they are out there.
On my 223ci I found that the fan opening was about two inches lower for the six cyl. I assume the higher schroud is for the V8. I was fortunate to have found both in So. Cal.
