F250 Largest tire size? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-09-2010, 05:01 PM
vera123 vera123 is offline
vera123 is starting off with a positive reputation.
I have a 2004 F250 Super duty. Does anyone know what is the largest & fatest tire I can put on without a lift or leveling kit (and not rub naturally)?
Thank you in advance
Old 06-09-2010, 05:16 PM
Ace!'s Avatar
Ace! Ace! is offline
Ace! has a good reputation on FTE.Ace! has a good reputation on FTE.Ace! has a good reputation on FTE.
Had a buddy with 265/70/16 or something close. She rubbed unnaturally now and then.
Old 06-09-2010, 05:35 PM
drey04's Avatar
drey04 drey04 is online now
drey04 has a great reputation on FTE.drey04 has a great reputation on FTE.drey04 has a great reputation on FTE.drey04 has a great reputation on FTE.drey04 has a great reputation on FTE.
I got 285/75-16 tires on my F-250. She's lifted now, but the tires fit nicely when it was stock.
Old 06-09-2010, 05:45 PM
ken kenmnedy's Avatar
ken kenmnedy ken kenmnedy is offline
ken kenmnedy is gaining momentum as a positive member of FTE.
i run 275/75/16 the summer tires dont rub but the snow tires will at lock with the plow on
Old 06-09-2010, 07:27 PM
FI460's Avatar
FI460 FI460 is offline
FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.
285/75/16's fit stock.
Old 06-09-2010, 09:33 PM
TXHillCountry's Avatar
TXHillCountry TXHillCountry is offline
TXHillCountry is starting off with a positive reputation.
Do you have a gasser or diesel? Rear is no prob, but the diesels sit slightly lower in the front due tothe weight. But generally speaking, you're looking at 275's, perhaps 285's.
Drop a leveling kit on there and your talking 305s, 315s, etc. For less than the price of one tire and a few hours out of your afternoon, you can put the leveling kit on. I have to say, the leveling kit and the 305s are the best thing (price wise) I did to alter the look of my truck.
TX
Old 06-09-2010, 10:09 PM
Ace!'s Avatar
If you're willing to go to a 17" wheel you could go with a 255/80/17E
Old 06-09-2010, 10:17 PM
Quote:
255? Isn't that even skinnier than stock? I think he wants to go wider than stock.
Old 06-09-2010, 10:22 PM
Ace!'s Avatar
You're right, my bad. I think some Super Dutys do come with tires that narrow (or a 245), but the OP did want wider. I was thinking tallest without rubbing and when you go taller, if you go narrower, you can usually get away with more height.
Old 06-10-2010, 08:04 AM
Thanks everyone for the input. I did forget to mention that it is a gasser and not diesel. I would like to put a leveling kit on but heard that it may have an impact on motor vehicle inspection, is that true (NJ)? Also, if someone could recommend a 3" kit that's simple to install that would be great.
Thanks again!
Old 06-10-2010, 09:49 AM
Thanks again!
I'll let someone from NJ comment on the MVI, but I'd find that hard to believe. A good leveling kit is the one from ICON Vehicle Dynamics. Simple to install? I guess that depends on your level of expertise. All you are doing is inserting a mini spring pack under the stock spring pack. The job can be done with a couple of heavy duty jacks, some jackstands, and your basic hand tools. ICON has good documentation, and you'll get a lot of good support and feedback here.
rgds,
TX
Largest tire for a stock 2016 F-250 Super Duty? MRN III 1999 to 2016 Super Duty 12 12-09-2016 08:18 AM
F-250 Stock 18" wheels largest tire Moses2662 1999 to 2016 Super Duty 20 10-29-2016 09:26 AM
Tire Size jcammarata 1987 - 1996 F150 & Larger F-Series Trucks 4 04-02-2014 09:47 PM
2002 ford f350 6 " lift to be installed what's largest tires? superglide04 1999 to 2016 Super Duty 4 07-30-2013 01:52 PM
largest tires for 77 f250? 82airborne82 1973 - 1979 F-100 & Larger F-Series Trucks 0 09-12-2010 07:06 PM
Tags
04, 05, 2006, 2558017e, biggest, duty, f250, ford, largest, lift, size, stock, super, superduty, tire, without
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
