swapping a 302 with a 300
Old 06-09-2010, 03:34 PM
aj197816134's Avatar
aj197816134
aj197816134 is offline
Yes I know I am going backwards of most. Here is the situation My godfather has a 93 f-150 with 40,000 miles on the I-6 has automatic trans is 4x4, we redid the truck, new bed and all back in 06 but the frame is gone. I am going to look at a 1995 F-150 with a BAD 302 also automatic with 4x4 , how much of a hassle would it be to change this engine into the truck with the 302? I am looking for advice, I have my own thoughts. I am going to look at the truck with the bad motor tomorrow
Otherwise I might be doing some frame chopping and welding in new frame rails, perhaps a new thread.
Old 06-09-2010, 03:39 PM
slhf150's Avatar
slhf150
slhf150 is offline
I don't know anything about it - but from watching similar threads, I know the first thing the guys who *do* know are going to ask you is: what transmissions are in both trucks? And is one or the other 4x4, 4x2, or both the same?
Old 06-09-2010, 03:45 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
302 and 300 share the same bell pattern.
Since you have both trucks, this could be fairly easy. If both are stick or both are automatic, it will be easier.
'93 to '95 it should all interchange methinks.
FWIW, I think I'd rather rebuild or swap in an engine than attempt frame repairs. Lots of little things with both, but those little things under the truck by the fuel tank inside the crossmember... ymmv.
Old 06-09-2010, 03:47 PM
aj197816134
THANK YOU THANK YOU, i just did an edit of information, long day and the weather here dont help. Both automatic, both 4x4
Old 06-09-2010, 03:52 PM
Hitokori's Avatar
Hitokori
Hitokori is offline
it should be very easy then just get some new motor mounts and a pcm for the 300 and drop it in
Old 06-09-2010, 06:46 PM
aj197816134
new motor mount's no problem, parts stores have them. PCM could i just use the one from the truck the 300 is coming from>??
Old 06-09-2010, 07:36 PM
Hitokori's Avatar
Hitokori
Hitokori is offline
oh yea lol i thought the 300 was in an older truck lol with a non computer controlled trans.... yea it should be fine I THINK
Old 06-09-2010, 07:48 PM
todd31277's Avatar
todd31277
todd31277 is offline
old motor mounts will work too. your not going backwards with a 300-6 if you as me
Old 06-09-2010, 07:55 PM
Hitokori's Avatar
Hitokori
Hitokori is offline
yea old ones will work but they are cheap and u might as well change them while u have it out
Old 06-09-2010, 07:56 PM
lupin398's Avatar
lupin398
lupin398 is offline
You have the donor truck and the truck you're working on. You should be A-ok. If it were me I'd be workin' on swapping it in already, you won't be sorry.
And I suggest against chopping and welding on the frame since that will destroy the temper of the steel that helps keep it so rigid.
And I further the "Not going backwards". I have a 300 as well, it's a great truck motor.
Old 06-09-2010, 08:02 PM
aj197816134
Thanks guys, I agree on the 300. I prefer it in a truck over the 302, although i have experience with a high mileage 302 but ne way. I will be finalizing the deal on the newer 95 truck, the old frame on the 93 is just worn out, My god father lives on very rough roads, and is 78 years old i want it to be safe. I mean i am not kidding when I say the engine is a 93 with around 40,000.
I will keep you posted,
Old 06-09-2010, 08:29 PM
RJG1987's Avatar
RJG1987
RJG1987 is offline
love that 300 4.9
Old 06-11-2010, 12:26 AM
aj197816134
Went and purchased the truck tonight, I wont be bringing it home until Monday. has a 302 thats blown with a 4Rw70 trans, i have to check but the truck with the 300 has a E4OD have to check in the morning
Old 06-11-2010, 05:24 AM
lew52's Avatar
lew52
lew52 is offline
Dont throw out the 302 , someone will want the roller accessories off of it , if its a mass air truck save the harness & meter & computer.....Lew
Old 06-11-2010, 06:02 AM
currituckF150's Avatar
currituckF150
currituckF150 is offline
AJ, I would suggest looking at the wiring diagrams on Ford Fuel Injection.com to get familiar with each trucks wiring. There are differences between the transmission wiring. The good thing is the wiring harnesses can be switched between trucks. If it were me, I would swap engine, trans, & t-case along w the necessary wiring. Good Luck!
Quick Reply: swapping a 302 with a 300
