Dana 60 vs. Ford 9" - Ford Truck Enthusiasts Forums
Dana 60 vs. Ford 9"
Old 02-05-2003, 06:46 AM
dburgess dburgess is offline
dburgess is starting off with a positive reputation.
Dana 60 vs. Ford 9"
What is the weight carrying ability and towing capacity of these truck axles.
1969 dana 60: with 9 3/4" ring gear and 16 spline axles which are
only 1 3/16" in diameter?
1976 ford 9" truck rearend with 31 spline axles. Don't know the
axle diameter?
Thanks, Duane in VA.
Old 02-05-2003, 08:57 AM
tw's Avatar
tw tw is offline
tw is starting off with a positive reputation.
Dana 60 vs. Ford 9"
I dont know the exact weight, but the Dana can carry a much heavier load. Its full floating, unlike the ford 9". Just so youre aware, the 69 Dana 60 isnt as wide as the 76 9".
It seems that in the 67-72 pickups, the rear is a couple inches narrower than the front. I have a 72 Dana 60 posi i was gona put in the back of my 78, but decided it would look stupid, and not be worth the trouble.
Tony Warren
Nebraska
Old 02-05-2003, 07:47 PM
alpo23 alpo23 is offline
alpo23 is starting off with a positive reputation.
Dana 60 vs. Ford 9"
axle diameter?
The D-60 is a work horse for carrying loads. The double timken bearings that allow it to be full-floating is the reason behind this. Unless you're going to be using big (+35") tires and lots of skinny pedal then the 16 splines will be ok.
The D60 vs 9" debate is never ending. each has it's pro's and con's. If you're using it for working then D60.
Eric
Ford 10.25" vs. DANA 60 TURBO Clutch, Transmission, Differential, Axle & Transfer Case 8 09-29-2016 01:44 AM
2008 F350 Dana 60 Front Axle buckin69bronco Ford Truck Parts for Sale 0 02-24-2015 01:57 PM
1970 f250 2wd rear axle info Green_Monster 1967 - 1972 F-100 & Larger F-Series Trucks 6 07-31-2009 08:30 AM
Sterling 9.75 vs. Dana 60 Broncojohn Clutch, Transmission, Differential, Axle & Transfer Case 0 09-23-2004 05:09 AM
16 spline Dana 60 ????? bigblue Clutch, Transmission, Differential, Axle & Transfer Case 8 12-02-2002 10:52 PM
Tags
60, capacity, dana, ford, inch, towing, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
