1990 f-250 needs help....
Hey guys i need some help and advice, i just picked up this truck, 1990 f-250 9"'s of lift with 36*14.5s.
It looks like someone put alot of time into this truck but the owner after him i belive kinda killed it. The truck has no 1st or 2nd gear... m50d...The second day i drove it (yes i did check the oil) the motor (302 carb) Locked up on me.... So now i have a dead engine, dead tranny but a solid frame also has a dent in door and front fender... so what do i do? i would like to get a efi 351 installed into her again, but the wireing is all hacked... push button start, switch for coil and switch for fuel pump.... Any ideas??? or has anyone seen the truck on here before? thanks,
Donnie
Donnie
I second the above.
I don't know where you live, but look in the NE for a rusted out truck with the 351 and tranny of your choice...then transplant the drive line. You would also get the wiring harness and other associated parts that will make costs add up if you do the swap without a donor vehicle.
A couple dents on a truck are fine to me as I use mine for working around the house, so my solution won't fix your body.
Roller150
01-04-2011 07:13 AM
