2002 E150 - Seatbelt Warning Light/Sensor malfunction - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 06-08-2010, 07:46 AM
whalerron whalerron is offline
whalerron is starting off with a positive reputation.
The seatbelt sensor for my 2002 E150 is malfunctioning and causing the warning bell to ring and it is causing the light on the dash to flash. I think the problem is in the driver side seat sensor or belt latch.
1) Has anyone else had this problem and if so, how did you fix it?
2) Can I somehow clean the sensor in the latch mechanism to fix the problem?
3) If not, how do I replace the sensor? I am hesitant to mess with it because the airbag sensor is also connected into the seatbelt warning harness at the driver's seat.
Thanks,
Ron
Old 06-08-2010, 07:47 AM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
Try resetting the computers.
Old 06-08-2010, 07:49 AM
Do I accomplish that by removing the battery cable for some set period of time or is there another method?
Intigrated seatbelt wont retract 03 F-250 Semper-Ford 1999 to 2016 Super Duty 16 02-07-2016 01:15 AM
Did the 06 to 03 seat swap, now airbag light issue ketel0ne 1999 to 2016 Super Duty 2 04-15-2014 10:10 PM
How to Replace Driver Side Seat Belt jnbdykema Excursion - King of SUVs 0 09-27-2011 05:07 PM
turning off the seat belt warning Longland 1999 to 2016 Super Duty 21 03-27-2011 02:44 AM
Seatbelt replacement? Dannym 1968-2013 Full Size Vans 4 01-14-2010 04:26 AM
Tags
2001, 2002, 2003, airbag, alarm, bell, belt, e350, explorer, f150, ford, malfunction, problem, problems, seat, warning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
