how to grease suspension & steering - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-07-2010, 08:35 PM
bigred66's Avatar
bigred66 bigred66 is offline
bigred66 is starting off with a positive reputation.
I was gonna give the truck a lube job but I noticed none of the components have grease fittings. Is there any way to lube these parts?
Old 06-07-2010, 09:02 PM
powerstroker11 powerstroker11 is offline
powerstroker11 is starting off with a positive reputation.
needle grease it through the boot but then youll have a hole in the boot for water/dirt get in. id wait for it to wear out and then replace it with grease-able components
Old 06-07-2010, 09:38 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
If you are extremely adept and clever, it is possible to drill holes in the plug (without any metal shavings getting in), and then adding the fittings.
Are you sure there is not a removable bolt?
Old 06-08-2010, 12:24 AM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
OEM parts are sealed. Most replace with parts that accept grease fittings, once the OEM parts are worn out.
Old 06-08-2010, 09:11 AM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
I wouldn't worry about it now, I would do what I had to do almost a month ago and just replace the ball joints with Moogs. They're greaseable, better than OEM, and carries a lifetime warranty if you get them from Advance Auto.
I'd also do your tie rods while I was down there...
Greasing E-Z lube bearing RV_Tech Fifth Wheel & Gooseneck RV Towing 41 12-26-2015 10:16 AM
Grease Fittings location chi6488 6.4L Power Stroke Diesel 6 08-18-2014 04:58 AM
5th wheel lube- grease or lube plate? mongo75 Fifth Wheel & Gooseneck RV Towing 22 04-05-2011 11:51 PM
Lube/Grease fitting on top of steering knuckle? kosb 1999 to 2016 Super Duty 5 07-02-2009 05:01 PM
2007 F-150 Chassis Lube 1saxman 2004 - 2008 F150 2 10-15-2007 04:58 PM
Tags
1999, 60, expedition, f150, f250, ffor, ford, grease, greasing, job, lube, steering, suspension, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
