Is there a place to T in for boost gauge?
Check DieselManor's gauge install sheets: DieselManor - Installation Sheets
I installed the Diesel Manor gauge set a few years ago and did the t tap in the map sensor line but it caused the boost gauge to fluctuate wildly. After talking to their tech help I was advised that tying into the intake elbow would eliminate the problem. I removed the elbow pretty easily and was able to drill and tap it without any problems and it works flawlessly. As suggested through, a 30 pound boost gauge is not quite enough as I can easily peg mine while towing.
I have a 35PSI and it's fine for towing/everyday driving. If you're pulling the intake elbow to tap it, be very careful when you re-install the bolts. They are easily stripped, even when going to the spec'ed TQ value. Get them snug, that's all you need. Snug them up again after a couple of heat cycles and you're good to go.
Metal twister
General Diesel Discussion
07-29-2016 12:34 PM
SuperDoodieDutyDude
1999 to 2016 Super Duty
11-03-2010 08:29 AM
