Next Mod?
Next Mod?
Just installed new exhaust from downpipe back. Sounds great, but don't really notice too much more power than stock. Looking for a little more power in 2nd gear towing my travel trailer up hills. If I don't get a run at a hill it seems to bog down between 35-45 mph. Other than that it's fine. I am looking to the next mod that will give me more power for not that much $.
The IDM mod is a good one. Thanks for using my link there George. Makes me feel all warm and fuzzy inside knowing other people like my write-up.
The 10k mod isn't that good IMO. Saving up for gauges and a good chip is better.
Also, do you have a larger transmission cooler already? Definately a must have item for towing and even every day driving.
X2
Did you upgrade the downpipe with your exhaust or is it still stock? Stock downpipe is very restrictive.
FPR shim is good also. Make sure you are getting good fuel pressure, but not too much. You don't want more than 80psi at idle, but should have more than 45psi.
Between 65-75 is ideal.
i had to put 2 inline to get exactly 75k, they are big also. just standard carbon resistors. iam going on a year now, no problems,yet. dang! i said something
