2005 F250 4x4 Climate Control Issue
My 2005 F 250 PSD has done that three times since 2005 next time try turning on the headlights. Its worked every time for mine brought the climate control back on. I did read where it was a sign of future climate control failure and the unit has to be replaced but so far so good. knock on wood!
The following users liked this post:
I've had my 2005 since it was new and had that happen one time about a year ago. Before I hooked up our 5th wheel I went to top off the gas tank before a trip. On the way to the gas station I noticed the display was blank and there didn't seem to anything I could do to bring it back to life. After refueling I started the truck and it came back on like nothing ever was wrong and has work flawlessly ever since.
Rob
Rob
Mine has done it once or twice a year for the last 3 years.
At first I would stop somewhere and shut off the truck and when I would restart the truck it would work fine, then I learned that all you have to do is turn the headlight switch from auto to off once or twice and that works fine!
It seems to be just a glitch in the system.
I have a 05 F250 and it has been doing the same thing. This last time it has been off for 2 days. Read this thread, then went out and turned the lights on and off a couple times with the ign. switch off, put the key in and turned it on and the climate control started working again. Thanks, saved me a trip to the dealer.
