HELP! What is another name for the Fuel Filter Restriction Sensor - Ford Truck Enthusiasts Forums
Old 06-06-2010, 08:27 PM
TimmyAbrams TimmyAbrams is offline
TimmyAbrams is starting off with a positive reputation.
1997 F-250 PSD
I found my fuel filter restriction sensor leaking this evening! Is there another name for that part so that I can find it at advance auto, autozone, or napa? I have those stores local, but the dealership here does not carry parts. The leak is about a drop every two to three seconds, so it's a decent leak.
I gotta drive the truck like that tomorrow, and I'll fix it in the evening!
Thanks auto gawds!
Tim
Old 06-06-2010, 09:22 PM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Fuel filter restriction sensor.................................
Can i get a picture? haha.
I don't know of any sensors like that.
are you sure your not talking about the water in fuel sensor?
Old 06-06-2010, 09:55 PM
Hussler's Avatar
Hussler Hussler is online now
Hussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to all
Fuel filter vacuum switch, top sensor.
Old 06-06-2010, 10:33 PM
Talyn's Avatar
I must not have one of those?
Old 06-07-2010, 01:15 AM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to all
1/8" NPT plug from the hardware store will fix it also. Careful on the R & R in any case. The FPR (the thing the sensor is attached to) is pretty fragile. Could crack if you over tighten the plug or sensor.
Old 06-07-2010, 08:28 AM
Talyn's Avatar
picture anyone?
Old 06-07-2010, 11:00 AM
pjwoolw's Avatar
Here you go.
Old 06-07-2010, 07:54 PM
Thanks guys, I cannot justify spending the $70 from a stealership for the part and shipping. Today, I installed a 3/8" brass pipe pung/end cap into the space. I dont remember the thread pitch, but it was either 18 or 20 tpi. The pipe bung was a whopping 37 cents. I might put the right part in eventually, but probably not. I'm a cheap azz.
(not so)advance auto, autostoned, and crapa could not get me a new sensor, no matter what i called it. Such is life.
Thanks all!
Old 06-07-2010, 11:43 PM
Talyn's Avatar
oh, my 94 doesn't have that. =)
Old 06-08-2010, 04:10 PM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Wink
Quote:
Yes it has, but its located in the bottom of the rear part of the cannister, look here
Talyn's Avatar
I dont have it. =)
Old 06-08-2010, 04:15 PM
RÖENTGEEP's Avatar
FOREIGN GURU
Question
I dont have it. =)
Uhhhh? did you see the schematic?, if there is not the switch, surely somebody put there the 1/8 NPT plug before.
Old 06-13-2011, 01:18 AM
Trader_Dick Trader_Dick is offline
Trader_Dick is starting off with a positive reputation.
Fuel Filter Vacuum / Restriction Sensor
Seriously? I can just plug the hole and move on with my life?
What are the downsides of just plugging the hole and moving on, instead of buying and installing a new fuel filter vacuum switch or fuel filter restriction sensor, or whatever it's called?
Thanks,
Dick
Old 06-13-2011, 01:22 AM
pjwoolw's Avatar
Yep. Just keep up on your fuel filter changes and keep the return screen in the bowl clean. Don't tighten the plug to tight. Could crack the FPR.
Old 06-13-2011, 02:19 AM
Thanks
OK, 1/8th inch 18 or 20 threads per inch, right?
Anything special as a washer when I plug this? What length should I use? The thing is dripping 1 per second now, and I'd like to get 18 MPG on my 1996 f-250 power-stroke that has 291,000 miles, instead of the 16.5 I'm getting now. Of course, when I change the gears from 4:10 that may help, as will adding a Banks programer... anyone have any other ideas?
Thanks,
Dick
Fuel bowl restriction sensor green_95 1994.5 - 1997 7.3L Power Stroke Diesel 4 11-27-2015 06:39 PM
HELP need 97 FPR part number! OBSEnthusiast 1994.5 - 1997 7.3L Power Stroke Diesel 1 10-07-2015 12:24 PM
Quick question - fuel leak cowmilker08 1994.5 - 1997 7.3L Power Stroke Diesel 5 02-13-2014 09:52 AM
Is this sensor really needed? TexasDiesel97 1994.5 - 1997 7.3L Power Stroke Diesel 4 11-26-2011 06:57 PM
Finally found the pesky fuel leak SF-ESS 1994.5 - 1997 7.3L Power Stroke Diesel 7 11-25-2009 09:32 PM
Tags
1997, 73, 73l, 97, diesel, f250, filter, ford, fpr, fuel, powerstroke, restriction, sensor, switch, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
