Stupid Transmission...
Old 06-13-2011, 11:23 AM
Awitte58's Avatar
Awitte58
Awitte58 is offline
Unhappy Stupid Transmission...
In my 97 f350 I still have my E40D.. I recently had a leak out of the front flywheel cover thing near the oil pan.
I was told it was the front seal. We replaced the front and rear seal and trans filter and everything... and in the trans pan it looked good..not any big chips on the magnet.
Got it back in on Friday and drove it around a bit this past weekend. It shifted great, Better actually than before (trans filter was pretty nasty).
Everytime I parked Id get out and check under it before shuttin er down. There wasn't like a drip or anything out of the cover at idle while parked. I cant really check during driving...
But then Id come out later (say overnight or a good 6 hours)and theres a decent size puddle. a good 5" diameter amount of puddle or drips around it.
WHAT IS WRONG!?
I am kinda frightened because one mechanic said maybe the trans has a crack in it...but the leaking is all near that front flywheel out of the inspection cover.
Old 06-13-2011, 12:04 PM
GreaseMonky's Avatar
GreaseMonky
GreaseMonky is offline
My 1997 kinda did that then all of a sudden one day at a light it puked its guts out, not sure what the problem was, since i put a ZF5 in right after
Old 06-13-2011, 04:02 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
How did the torque converter hub surface look? Was it perfectly smooth? How about the bushing the torque converter hub rides in? If it is worn the seal won't hold.
Old 06-13-2011, 08:45 PM
RRranch's Avatar
RRranch
RRranch is offline
Every one I saw that leaked out the front seal had a trashed pump in it. Kinda surprising someone would go through the trouble of doing a seal and not do the pump. Stupid mechanics you should be saying!
Old 06-13-2011, 10:06 PM
joe_13894's Avatar
joe_13894
joe_13894 is offline
I replaced the front seal in mine 40K ago and knock on wood it's still fine. The torque converter bore looked fine and the pump bushing looked fine so I put it back together with nothing more than a new seal.
The early E4OD transmissions had bad front seals and they would fail from heat.
fordcrzymike
1997 - 2003 F150
06-27-2017 10:00 AM
Diesel 724
17
10-21-2014 12:07 PM
austin.clark2
08-25-2014 11:08 AM
SkySkiJason
18
09-20-2010 07:39 AM
Stomper4x4
1978 - 1996 Big Bronco
16
09-24-2003 12:49 PM
Quick Reply: Stupid Transmission...
