Can't install distributor - oil pump shaft not seated - Ford Truck Enthusiasts Forums
Old 06-06-2010, 05:26 PM
balingwire balingwire is offline
balingwire is starting off with a positive reputation.
I can't install the distributor in my '78 Ford (351M). It seems like the oil pump shaft is not seated in the oil pump. What's the best way to make sure the shaft is seated in the oil pump? I think that it may have lifted up just enough when I pulled the old distributor. I'm thinking of getting a oil pump primer shaft and trying that. I've had the normal aggravating trouble of getting distributors to fully seat/engage, but nothing like this. I've worked on and off on this for over a week, and I'm no closer to getting it now. Thank you.
Old 06-06-2010, 05:37 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Bump the starter, it'll fall right in.
Josh
Old 06-06-2010, 06:22 PM
JBradley500's Avatar
JBradley500 JBradley500 is offline
JBradley500 is starting off with a positive reputation.
i installed mine out of the engine and just rolled the engine over by hand (well with a 1/2" breaker bar).... seemed to be pretty easy that way
Old 06-06-2010, 07:20 PM
I tried bumping the starter, and it didn't work. I'll try the breaker bar and turn the engine.
Old 06-06-2010, 08:11 PM
79FordBlake's Avatar
79FordBlake 79FordBlake is offline
79FordBlake is starting off with a positive reputation.
Another possibility is shaft is in oil pump all the way but not in dizzy all the way. Has to be lined up just right for dizzy to drop down on it all the way. Kinda a pain sometimes when your tryin to get the rotor to land in the right position at the same time.
I've had this problem many times, sometimes they drop right in other times they fight awhile, lol.
Old 07-08-2010, 08:18 PM
As posted in another thread when this had me whipped:
I'm not proud - it whipped me, but Dad discovered that the oil pump shaft had come out of the pump. He used a socket (can't remember the size) and 1/4"-drive long extension and got it seated. The distributor then slipped in like always. We timed it, then guestimated the timing setting by idle - ~600 rpm, checked it, and it was dead on - 12 degrees advanced. Glad to have it going, and learned from it.
Old 07-08-2010, 08:40 PM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
for reference it was or should be a 5/16" socket.
Old 07-08-2010, 11:29 PM
whalerron whalerron is offline
whalerron is starting off with a positive reputation.
I too did mine with a socket. If you use this method, be VERY CAREFUL that you do not drop the socket off of the end of your extension when you try to remove it. I taped my socket to the extension.
Old 07-08-2010, 11:51 PM
JP808 JP808 is offline
JP808 is starting off with a positive reputation.
this happened to me and I used a magnet that was fixed to a telescoping handle ,I don't know what this tool is called but sears had several different sizes of this tool, when you have the shaft in its place just rotate the magnet off , should have no problem! best luck!
Old 12-28-2014, 11:29 PM
Buddy 3 Buddy 3 is offline
Buddy 3 is starting off with a positive reputation.
Bruce
I have had the same problem installing my distributer. I ended up using a spring loaded claw that has 4 thin metal jaws that extend out from a cable when a part on the end is depressed.y issue wasn't the distributer but the shaft seating into the oil pump. I used the claw to grasp the hex Allen shaft and manipulate the shaft up and down and circular rotation. When the shaft seated down into the pump my problem was solved. What a bugger.
Restabbing distributor TheSterling 1973 - 1979 F-100 & Larger F-Series Trucks 8 06-20-2016 08:22 PM
Distributor fitment redbayredneck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 01-05-2016 09:01 PM
MSD distributor won't install 48 Steel 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 4 02-04-2014 04:07 PM
351W oil pump drive rod jammed. FordFETruck Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 05-19-2013 01:47 PM
distributor won't drop in slammed77 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 9 06-02-2004 11:20 PM
Tags
29, 302, 351, 400, distributor, ford, install, installing, oil, pump, rod, sbf, seating, shaft, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
