ac blows cold air out defrost vent only - Ford Truck Enthusiasts Forums
Old 11-07-2014, 02:40 PM
How-Tos on this Topic
Last edit by: IB Cristina
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
Old 06-06-2010, 04:34 PM
shelby5.4 shelby5.4 is offline
shelby5.4 is starting off with a positive reputation.
My 06 F250 crew with the 6.0 starting blowing the cold AC out the defrost vent and will not switch to the dash vents. It's goning to hit 108 today and stay around 105 for the rest of the week. Can someone step me thru some troubleshooting.
thanks, Jim
Old 06-06-2010, 08:50 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
The FAQs above will get you started.
Old 06-08-2010, 12:30 AM
FAQ ???
Thanks for the answer, but when I go to the FAQ section it states that I need 25 post to use the FAQ search. Am I just missing something or is it off limits to those who don't use the site very often? Sorry to be a pest, but I really want to start tracking down the ac problem. thanks again, Jim
Old 06-08-2010, 12:43 AM
stuart1 stuart1 is offline
stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.
There is a door in the blower box that is not moving.
It can be either electrically or vacuum controlled.
At times the hinge will break.
Old 06-08-2010, 07:04 AM
Quote:
The second post in this section says:
Read First: HVAC FAQs for 97-03 F-Series (including Navigator & Expedition)
When something says Read First: , you are supposed to READ IT FIRST.
You are thinking of the temperature blend door which is not the issue.
Old 06-08-2010, 12:38 PM
You are incorrect.
The door I am talking of directs airflow to the defrost and floor vents.When the hinge breaks air is directed to defrost.
Old 06-08-2010, 09:04 PM
Quote:
Originally Posted by stuart1 View Post
You are incorrect.
Perhaps. Never seen one of those break compared to all the broken blend doors.
Since the airflow also defaults to defrost when vacuum is lost and that is an extraordinarily common failure, it pays more often to go with the odds in the absence of any data to the contrary.
Old 06-08-2010, 09:22 PM
ford-speed ford-speed is offline
ford-speed is starting off with a positive reputation.
Look under the dash. The switch where you select the mode works by means of small vacuum tubes attached to it. You either seem to have a leak, or a hose is simply disconnected, leaving the AC on a single (frozen) defrost vent position, because it is unable to do anything else.
Old 06-10-2010, 04:29 PM
thanks for info, vacumn device ??
Thanks everyone for the help.
Here is what I found, please excuse my lack of technical names. I pulled the line that looks like it was heading thru the firewall and found little or no vacumn. The same is true for the line attached to some kind of diaphram on what looks like a water line.
Traced those back to a cannister like device being fed by a pump on the firewall. Pump seemed to be running and has some vacumn if you disconnect the lines.( not sure how much vacummn is normal)
Cannister feeds another device on the firewall (small plastic looking thing with a white top and two lines attached) I removed those two lines and plugged them. AC vents starting working.
What is that device and what does it do ? It looks like one of the lines heads down along the engine and disappears. To where ?? I assume the other line is feeding vacumn to the device.
thanks, Jim
Old 06-10-2010, 11:12 PM
Yup
A door problem..
I've seen it oodles of times.
Glad you got it repaired.
Old 06-10-2010, 11:27 PM
Speaking of reading comprehension.
His truck is a 96.
The HVAC facts state 97.
Hmmmmmmm
Old 06-11-2010, 07:46 AM
His truck is a 96.
Hmmmmmmm
He has an 06, not a 96. Talk about misplaced concern in complaining about "reading comprehension"....
Before directing him to the posted FAQs, I first verified that the 06 utilized the same control system as the previous version. If it had been a different system, different advice would have been given.
Look, we both have extensive experience and knowledge of these systems that may be of use to the general membership. I suggest stopping your attempt to get a pissing contest going and instead to focus on assisting the "average Joe".
Old 06-11-2010, 09:04 AM
Haha, his is an 06, you sent him to 03.
So you do read.
You could attempt to give sound advice rather than chiding someone with a know it all attitude.
You know very well people do not read information.
No pissing match.
Old 06-11-2010, 12:45 PM
still confused on what these parts are
OK.
I do appreciate that a lot of good people share their knowledge for free to complete strangers.
In my last post , I was hoping to find out about some components. What they are, where they go and what they do. Especially the plastic component on the fenderwall that has a line coming from the cannister and one going down alongside the engine. How do I determine that it is working properly ? Where does the line go ? How strong should the vacumn feel ? thanks again, Jim
Old 06-13-2010, 06:00 PM
still hoping someone can answer AC question
Can someone tell me what the component is that is mounted to the inner fenderwell driectly behind the passenger side battery. It has 3 electrical wires ( in one connection) and 2 vacumn lines attached to it. Where does the vacumn line go ? thanks, Jim
Help with crazy A/C functioning wgm114 Cooling, Heating, Ventilation & A/C 1 08-12-2012 10:24 PM
Help me! A/C acting wacky wgm114 1999 to 2016 Super Duty 5 08-06-2012 07:04 AM
AC blowing only out of the defrost vents G550_Capt Excursion - King of SUVs 11 07-14-2011 06:27 PM
A/C only blows from defrost and floor Ricky Mayo Cooling, Heating, Ventilation & A/C 3 09-28-2010 10:05 PM
Speedyg speedyg 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 04-08-2004 07:03 PM
Tags
02, 2003, ac, air, blowing, blows, defrost, defroster, escape, excursion, f150, f350, ford, truck, vent, vents
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
