casting numbers - Page 2 - Ford Truck Enthusiasts Forums
casting numbers
Old 08-10-2010, 05:24 PM
steponit steponit is offline
steponit is gaining momentum as a positive member of FTE.
Block numbers are D3TE-6015-AA. Then there is 3027.
are you sure that is an 0 and not a C ?
3C27 would mean March 27, 1973
2nd digit is a LETTER not a number
Ford wouldn't use an O because it would be confused with an 0
Old 08-10-2010, 05:35 PM
Cekkent Cekkent is offline
Cekkent is starting off with a positive reputation.
Typing "D3TE-6015-AA" into Google, comes up as being a 240 cubic inch inline 6.
If it's still there, theres a metal tag bolted to the engine, above the distributor, that should say either "240" or "300" on it.
Old 08-10-2010, 06:18 PM
fvassar fvassar is offline
fvassar is starting off with a positive reputation.
thanks for the info
it sure helps
and it looks like a D NOT O.
SO WOULD THAT MEAN APRIL?
Old 08-10-2010, 06:21 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
In two words: Im Possible.
The 240 & 300 I-6's share the exact same bare block, so thru 1974, the casting numbers that apply to a 240 also apply to a 300.
The 240 was cancelled at the end of the 1974 model run. Casting numbers cannot be cross referenced to actual Ford part numbers.
240 vs 300: The bore is the same (4.00"), the 300 has a longer stroke. Measuring the stroke is the only way to determine what size the engine is without tearing it down.
240: 3.18" / 300 = 3.98"
Is the truck a 1972...or not? If it is, it would not have a D3TE block, so the engine's been swapped.
The second digit of the casting date is a letter which refers to the month. There is no month of O since M refers to December.
A refers to January, B to February and etc. The letter I is skipped.
Old 08-10-2010, 08:17 PM
thanks
i was thinking switched engine too.
i will check the stoke to see if 240 or 300.
i noticed who ever gave tunne up
gaped at .043. but spec show .034.
so i am trying to make sure what i got.
i know it calls for a bf 42 plug. thanks for the help,
i am new at this and am greatful.
it has a oil bath air filter. is there something else
i can upgrade to.
Old 08-10-2010, 10:12 PM
Unbeleiveable
D3TE - only means it was an engine part designed for a 73 Light Truck
The AA auffix means it had a couple of changes by the time trhat Block was ACTUALLY cast
I suggest to do more research intro how Ford Numbering works.
D3TZ could have been for any engine that was designed for a 73 Truck
6015 is the BLock engineering reference number
The Suffix is for change ups to the original design
Old 08-11-2010, 03:43 AM
Ford used the same casting number for several years on some engines (D1VE-6015-AB, AB1, AB2: 1971/73 429; 1971/78 and some 1979 460's).
6015 is the basic bare block casting number. 6010 is the bare block basic part number.
D3TE-6015-AA refers to 1973, but Ford may have used this same bare block casting number for 1974, 1975 or?
Old 08-11-2010, 08:32 AM
i noticed on this truck, there is 7 leaf springs in front
and 8 leaf springs in back. this engine seems to have
low gears. 1st and 2nd very low. wheel base is 104".
can anyone help me with that.
Old 08-11-2010, 09:18 AM
So far, all you have posted is the year, I-6 engine, the number of leaf springs and the wheelbase of 104 inches.
If you post the VIN and all the codes found on the Warranty Plate, when decoded, you will learn more about your truck.
Old 08-11-2010, 09:39 AM
hi
thanks for comments
this truck is strange.
here is plate info
vin-P35BVP34479
secound row- wb-104- p351 - 0 a - 25
third row- 06100 - 124 - 3600 - 43
i went out and measured wheel base it is 104" axle to axle.
hope this info will lead to more info.
thanks frank
Old 08-11-2010, 10:10 AM
Quote:
Originally Posted by fvassar View Post
hi
thanks for comments
here is plate info
vin-P35BVP34479
thanks frank
There's nothing strange about it, and it's just what I thought it was, when you said the wheelbase is 104 inches.
You have P Series Parcel Delivery, the front doors slide back/forth.
P35 = P350 Parcel Delivery Chassis.
B = 300 1V 1-6.
V = Kentucky Truck Assembly Plant
P34479 = 1972.
104" Wheelbase.
MODEL code P351 = P350, 6100 lbs. Gross Vehicle Weight Rating.
TRANS code 0? A. There is no TRANS code of 0. A = New Process 435 4 Speed Manual Transmission.
AXLE code 25 = Dana 60 Rear Axle / 4.56-1 / non Limited Slip / 5300 lb. Rear Axle Capacity.
GVW 06100 = 6,100 lbs. Gross Vehicle Weight Rating.
124 net HP @ 3,600 RPM
DSO 43 = Milwaukee WI Ford District Sales Office, where the original selling dealer ordered the vehicle from.
Ford did not make the body it has, it was installed by an aftermarket body maker. All 1961/76 P Series were sold as a rolling chassis.
Only the front sheet metal, grille, lamps, dashboard, drivers seat was factory installed. The passenger seat was an option.
10's of 1000's of these trucks were sold to bakery's, so they became known as bread trucks.
Old 08-11-2010, 07:33 PM
thank you for the info.
it is really going to help
alot.
you are good at it.
and i want to thank everyone for their help
its nice to know what i have.
and i like it.
frankName:  011.jpg
Need CC's for GT40 Cobra vs GT40 Truck Heads Bamadawg63 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 9 09-24-2011 11:31 PM
4v intake manifold id FTE Ken FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 21 07-19-2008 05:54 PM
Flywheel Casting Number kellar Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 8 08-03-2007 03:48 PM
4.6L Casting numbers stantojl 1997 - 2003 F150 2 03-10-2004 10:49 AM
390 Rebuild rusty79 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 16 04-28-2001 08:07 AM
Tags
1972, 240, 300, 60, block, cast, casting, code, d3te6015, d3te6015aa, dana, engine, flathead, ford, number, numbers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
