bad fan clutch?? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
bad fan clutch??
Old 06-06-2010, 10:41 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
bad fan clutch??
on my 02, at idle the A/C don't work, and coolant temp is 215 degrees. if i hold 1500 rpm in neutral, it will climb to 225-235 degrees.
when i drive, the temps go down to 180-185, and the A/C starts working.
this sounds like a bad fan clutch, rite??
Old 06-06-2010, 11:42 AM
jwhitetail jwhitetail is offline
jwhitetail is gaining momentum as a positive member of FTE.
If your temp's get that high the fan should sound like a plane taking off. If not replace as soon as possible.
Old 06-06-2010, 11:44 AM
takotruckin takotruckin is offline
takotruckin has a good reputation on FTE.takotruckin has a good reputation on FTE.
Sounds like it. Toss a blanket in front of the grille at idle and watch the temp, when the fan locks up you WILL know it unless you are deaf, it sounds like a freakin airplane. I'd say if the engine will hit 220 or so without the fan locking up the clutch needs replaced. There is a specific air temp they are supposed to lockup at, I think its around 205-215.
Old 06-06-2010, 12:54 PM
ernesteugene's Avatar
ernesteugene ernesteugene is offline
ernesteugene has a very good reputation on FTE.ernesteugene has a very good reputation on FTE.ernesteugene has a very good reputation on FTE.
Below is a summary from the Ford Service Manual for testing the fan clutch ...and as you can see when the engine compartment temperature reaches 205*F the fan clutch fully engages and provides a maximum fan speed
Fan Clutch Test ...Maximum Speed Requirement...
1) Block off areas on each side of the radiator in the engine compartment and the front of the radiator grille. This will raise the temperature of the air striking the fan clutch and should cause the fan blade to operate at maximum speed.
2) Start the engine and run it at approximately 1,500 rpm until the normal operating temperature has been achieved.
3) Place the climate control function selector switch in the MAX A/C position and the blower motor switch in the HI position.
4) Adjust the strobe to 3,600 rpm for 7.3L diesel engines and adjust the engine speed until the strobe light flash and the water pump pulley mark are synchronized.
5) NOTE: The temperature of the air hitting the fan clutch should be above 96C (205F) for maximum fan speed.
6) If the fan blade speed is less than 2,850 rpm on 7.3L engines, install a new fan clutch.
Here's the complete version...
Quote:
Originally Posted by danskool View Post
...This help? found this out of my Service Manual ...Fan Clutch Test
Spin the fan blade (8600) by hand. A light resistance should be felt. If there is no resistance or very high resistance, the minimum and maximum fan speeds must be checked as follows:
Fan Clutch Test—Minimum Speed Requirement
Use a suitable marker to mark the water pump pulley (8509), one of the fan blade retaining bolts and the crankshaft pulley (6312).
Connect a tachometer to the engine.
Install a throttle adjusting tool.
Connect the Digital Photoelectric Tachometer.
WARNING: To avoid the possibility of personal injury or damage to the vehicle, do not operate the engine until the fan blade has been first examined for possible cracks and separation.
Operate the strobe light at 4,320 rpm for 5.4L and 6.8L engines and 3600 rpm for 7.3L diesel engines, and aim it at the water pump pulley. Adjust the engine speed until the light flash and the water pump pulley mark are synchronized.
Aim the strobe light at the fan blade bolts. Adjust the strobe light until the light flash is synchronized with the marked fan blade bolt (the fan blade appears to stand still).
The fan blade speed must not be greater than 1,900 rpm on 5.4L engines and 2,000 rpm on 6.8L and 7.3L engines.
Turn the engine off.
If the fan blade speed was greater than 1,900 rpm (on 5.4L) (on diesel engines and 6.8L, 2,000 rpm), install a new fan clutch (8A616).
Fan Clutch Test—Maximum Speed Requirement
Perform Steps 1 through 5 of the Fan Clutch Test—Minimum Speed Requirement.
Block off areas on each side of the radiator in the engine compartment and the front of the radiator grille (8200). This will raise the temperature of the air striking the fan clutch and should cause the fan blade to operate at maximum speed.
Adjust the strobe to 4,320 rpm for 5.4L and 6.8L engines and 3,600 rpm for 7.3L diesel engines.
Start the engine and adjust the engine speed until the strobe light flash and the water pump pulley mark are synchronized.
Aim the strobe light at the fan blade retaining bolts. Adjust the strobe light until the light flash is synchronized with the marked fan blade bolt (the fan blade appears to stand still).
If the fan blade speed is less than 3,600 rpm on 5.4L engines and 3,500 rpm on 6.8L engines, 2,850 rpm on 7.3L engines, install a new fan clutch.
Old 06-06-2010, 02:37 PM
i ain't rite
or i could just get the engine to temp, shut the truck off and see if i can turn the fan, rite??
cause i don't have a strobe, let alone one with an adjustable flash rate.
Old 06-06-2010, 03:29 PM
No, just let the truck get up to 220 or so and you should hear the fan lockup, it will be VERY loud and it will move ALOT of air. You may want to verify temp with a infrared gun if you have one, just to make sure your gauge isn't reading high.
Old 06-06-2010, 05:14 PM
i ain't rite
i got the engine temps from auto enginuity.
i have never heard the "jet engine sound"
Old 06-06-2010, 07:49 PM
If you have never heard the jet sound than go get a clutch and fix it.
Old 06-07-2010, 05:19 AM
i ain't rite
i wonder if the clutch from an older engine will work?? the clutch for the 02 is $170, and i have one for the idi and one for a early powerstroke sitting in the garage.
Old 06-07-2010, 10:35 AM
Fat Diesel's Avatar
Fat Diesel Fat Diesel is offline
Fat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud of
Tom I put a new one on mine yesterday, dating back to last summer my fan won't lock under heat/load. Brutal trying to tow in CA with the grades. I also flushed out the coolant now for the 2nd time since I'm at 11yrs/250K.
I have a set of calipers and could take some measurements if you want to try and compare my old fan clutch. I went to the cheap tool outlet store place and bought the huge 1 7/8" end wrench for $17 and the Napa Auto store had the big "tongs" for $21. But since you have a couple laying around I'm sure you know how to remove em!
I'm trying to avoid this again:
Old 06-07-2010, 11:25 AM
You can buy a Hayden or flexalite clutch replacement for 50 to 70$
Old 06-07-2010, 11:44 AM
rich77crewcab rich77crewcab is offline
rich77crewcab is starting off with a positive reputation.
you can also try e-bay, i have found some good stuff for my 77 there
Old 06-07-2010, 04:51 PM
i ain't rite
i looked all over the place this morning, and the best i could find was $167 from NAPA, with Parts guy Ed coming in a close second at $189.
then at 9 am i bought one from a guy on another forum for $30 plus shipping.
Old 06-07-2010, 04:57 PM
i ain't rite
i have had a set of OTC fan wrenches for almost 20 years now. best $50 i ever spent.
i know what you mean.
i did some tests this afternoon with the auto enginuity hooked up, and the trailer on back with a honda on it.
air temp was 78.
water temp topped out at 166, oil temp was 145, and trans fluid temp was 126
the truck is parked until the new fan clutch goes in it.
Old 06-07-2010, 05:41 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt Parts Guy Wyatt is offline
Former Vendor
Parts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud of
M.I.C.K.E.Y
HAHAHAHAHAHAHAHAHHA
6.0 Fan Feedback 88david 6.0L Power Stroke Diesel 1 04-13-2016 10:07 AM
A/C and System Ventilation Problems Pinzer Cooling, Heating, Ventilation & A/C 0 08-18-2015 02:23 PM
Horton electro Mechanical fan clutches? Anyone running one? junkkingranch Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 12-28-2013 06:26 AM
Need help with 2000 F350 A/C please Firefighterdan Cooling, Heating, Ventilation & A/C 4 08-22-2012 01:00 AM
A/C clutch not cycling 77bigblock 1987 - 1996 F150 & Larger F-Series Trucks 0 01-02-2010 11:35 PM
Tags
1986, 29, 73, bad, c7, check, clutch, f250, fan, ford, forum, removal, slector, sounds, speed, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
