95 powerstroke oil leaking - Ford Truck Enthusiasts Forums
Old 06-06-2010, 09:30 AM
strokin4x4 strokin4x4 is offline
strokin4x4 is starting off with a positive reputation.
i have a 95 powerstroke f-250 it has 211k miles on it i just did an oil change about a week to a week and a half ago but somehow it has leaked almost a gallon of oil between now and then. i usually park in the grass so i have not noticed it but i parked in the driveway last night and the was about a 6inch puddle under it this morning. im not sure where its coming from and thats the problem, it doesnt appear to be coming from the pan or oil filter but it also doesnt appear to be leaking from anywhere else ive always had a constant VERY small leak from the pan nut but never enough to have to add oil between changes. if anyone has any ideas of how to find the source of the leak or any idea of what to do about this please let me know.
Old 06-06-2010, 09:46 AM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Pedestal, IPR, HPOP.
These will all leak on ya.
Probably pedestal leak, or IPR.
Old 06-06-2010, 10:26 AM
427 fordman's Avatar
427 fordman 427 fordman is online now
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Ya you're gonna have to clean up top some and start it and see if you can find the leak. It's probably from up top, like william said. My bet is either the turbo pedestal or the plugs in the back of the heads.
Old 06-06-2010, 11:29 AM
1997F-350's Avatar
1997F-350 1997F-350 is offline
1997F-350 is gaining momentum as a positive member of FTE.1997F-350 is gaining momentum as a positive member of FTE.
if it turns out to be the plug(s) in the head they are way cheaper at IH...than ford. replaced one on my dads truck
Old 06-06-2010, 03:36 PM
fixitman1310 fixitman1310 is offline
fixitman1310 is starting off with a positive reputation.
have you checked the oil cooler drivers side under powersteering pump and manifold
Old 06-07-2010, 08:04 PM
wetsailor wetsailor is offline
wetsailor is starting off with a positive reputation.
If this is eng oil and not fuel,I had that prob, mine was where the dipstick enters the pan, there is a round metal pad that connects with a very large nut. there is an o-ring INSIDE the pan that goes bad. Sometimes tightening the nut will stop your leak, otherwise, you must replace the oring. This can be done without dropping the pan, but look up how to do it on this forum or pm me and I will see if I can find the link. good luck.
What should I do about a 92 4.0 leaking oil so bad? 1998Ranger25L153CID Ranger & B-Series 3 01-06-2015 02:51 AM
Oil Pan Leak behind harmonic balancer Eddie C 1994.5 - 1997 7.3L Power Stroke Diesel 4 07-22-2014 04:28 PM
Leak from Side of oil pan Eddie C 1994.5 - 1997 7.3L Power Stroke Diesel 10 04-30-2014 07:43 AM
Oil leak suggestions Carnes99 Modular V10 (6.8l) 5 02-06-2013 02:22 PM
Oil pan removal on a 97 Powerstroke farmnfly 1994.5 - 1997 7.3L Power Stroke Diesel 35 06-12-2011 10:05 AM
Tags
1999, 73, 95, driver, engine, filter, front, leak, leaking, nut, oil, pan, powerstroke, side, superduty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
