Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks Discuss the Early Eighties Bullnose Ford TruckSPONSORED BY:
  #1 (permalink)
Old 06-05-2010, 10:27 PM
Wicked Endings's Avatar
Wicked Endings Wicked Endings is offline
1985 Ford F-150
Wicked Endings is gaining momentum as a positive member of FTE.
What type of oil should I use?
I'm getting ready to change my oil in my 1985 Ford F-150.
The engine is a 300 Straight Six, 230,000 miles.
What would be the best oil to get?
What brand? What weight?
__________________
Paul
"Experience is the name everyone gives to their mistakes"
http://thefallofdemocracy.tripod.com/fallofdemocracy
North Carolina Chapter
1985 Ford F150//4.9 Straight Six Engine//Automatic C4 Transmission
  #2 (permalink)
Old 06-05-2010, 11:18 PM
fepowerguy8's Avatar
fepowerguy8 fepowerguy8 is offline
Garage is empty, add now
fepowerguy8 is gaining momentum as a positive member of FTE.
I personally like using 10w-40 on older such as what you have and any brand that uses dino oil, (valvoline, castrol, penzoil, quaker state, sinclair, amsoil) and a little blue bottle of STP oil treatment as it's very high in zinc and that's good for the engine. For oil filters I use Wix
__________________
1961 Ford Falcon Tudor Deluxe, 1961 Mercury Meteor 800 4 dr, 1966 Mercury Parklane 2dr, 1990 Dodge B250 Van. And lost without a pickup.
  #3 (permalink)
Old 06-06-2010, 01:51 AM
TheKirbyMan's Avatar
TheKirbyMan TheKirbyMan is offline
TheKirbyMan has a good reputation on FTE.TheKirbyMan has a good reputation on FTE.
I've ran Shell Rotella T 15w40 for a couple years with absolutely no problems. If it's good enough for dirty, sooty diesel engines in semis, it's good enough for a much cleaner gas engine.
For filters, I've had good experience with Motorcraft and Wix.
__________________
1981 F-150 Custom
| 302 | C6 | 9" 2.75 |
1995 Jeep Cherokee
| 4.0L | AW4 | One owner |
  #4 (permalink)
Old 06-06-2010, 06:31 AM
smashclash smashclash is offline
smashclash is starting off with a positive reputation.
i agree with the 10-w40. as for brands i'd go with fepowerguy said. pretty much all of them out there except for noname in-store brands like a proline, coastal, autozone (if they even make it). i guess a decent rule of thumb would be if you see the oil company advertise on nascar it's a safe enough brand to use (haha).
i usually watch the circulars and pickup whatevers on sale at the parts store. i think advance is running a special now with castrol oil and a puralator filter. i picked u some of those.
also, i've used fram, motorcraft, puralator filters and never had a problem. you'll see a lot of people swear off fram but i've had good experiences. i think as long as you're changing your oil every 3K it doesn't make much of a difference if any.
__________________
1986 F-150 XLT Lariat 4x4. Shortbed, 5.0, AOD, Limitied Slip rear, EFI, dual tanks, A/C (Still R-12)
  #5 (permalink)
Old 06-06-2010, 11:16 AM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to all
I totally agree. I use 15W-40 diesel oil and wix or motorcraft filters. Rotella is usually the easiest find, as nearly everyone carries it.
I'm one that will not touch a fram oil filter. I've had people try to tell me they are fine, but I've seen one that ruined an engine. I believe in the adage of "screw me once, shame on you, screw me twice, shame on me".
__________________
1980 F-150 300 I6, C6 & 9" rearend. The workhorse. 300K+
1974 F100 Ranger XLT 390, C6 3.25 axle. Dad bought it new, drove it over 500K. Now that he can no longer drive it came to me. Value: Priceless.
1983 Mazda RX7 1.1L Rotary. The show/autocross/toy. 231K
1995 Mazda B2300 (undercover Ford)
  #6 (permalink)
Old 06-06-2010, 12:52 PM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Methanoholic
Festus Hagen has a very good reputation on FTE.Festus Hagen has a very good reputation on FTE.Festus Hagen has a very good reputation on FTE.Festus Hagen has a very good reputation on FTE.
Fram's anti drain back valve is made of cardboard, any good filter (Napa Gold, Wix) has a metal valve, they hold up and seal better unlike the Fram.
-Enjoy
fh : )_~
__________________
-= Improve Knowledge ... Share your's! =-
WANTED: Factory Turbo Wastegate Housing.
1994 F350 XLT CrewCab Dually IDIT ZF5 4.10's
1986 F250 SuperCab Dually 4WD 7.3IDI T19 BW1345 D50/60TTB Sterling 10.25 3.55's
1991 F250 StandardCab 2WD NO-IDI NO-ZF5 Sterling 10.25 NO-4.10's - Gone to the Toyota factory!
  #7 (permalink)
Old 06-06-2010, 02:08 PM
newrider3's Avatar
newrider3 newrider3 is offline
1982 Ford F-100
newrider3 is gaining momentum as a positive member of FTE.
Currently I'm running a Napa brand filter (it was free) for a 460 on my 300. It screws right on, and is almost twice as long as the standard filter... more capacity and filtration can't hurt, right?
__________________
1982 F-100 Shortbed 2wd - 300/6: Clifford Intake, 500cfm Edelbrock AVS, EFI manifolds, true duals, COMP 260H, port and polish, - M5R2 trans - 3.25 9"
1997 F-350 Crew Cab Longbed 4x4 - 7.3 PSD 5spd - beat to crap work truck resurrection
  #8 (permalink)
Old 06-06-2010, 02:17 PM
I don't know for sure about the standard NAPA filter, but the NAPA gold is made by wix.
__________________
  #9 (permalink)
Old 06-06-2010, 02:24 PM
Methanoholic
The deal with a larger filter boils down to filtration surface area, they do not filter better, they just don't plug as quickly.
Personally, I do not like the plain Napa filters, Napa Gold or nothing from Napa... The Napa Gold is a Wix filter.
-Enjoy
fh : )_~
__________________
Tags
10w40, 1986, 1990, 1997, 2005, 26, diesel, dodge, explorer, f250, ford, kind, oil, type, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
