Good place to run power inverter cables?
Old 06-05-2010, 06:34 PM
rhkcommander959's Avatar
rhkcommander959
rhkcommander959 is offline
Wheres a good place to run power inverter cables through the cab? I got a F250 87
Old 06-05-2010, 06:39 PM
LCAM-01XA's Avatar
LCAM-01XA
LCAM-01XA is offline
I run mine though the grommet for the speedometer cable...
Old 06-05-2010, 08:13 PM
rhkcommander959
I got two 4 gauge cables 8 ft long. Been looking around. I'll see if that's a good run. Is there any room around the shifter colum like under the boot? Back when i bought the truck the reverse light wires were run through there an inch to a toggle
I'd like to mount it behind the seat, I got a cobra cpi 1575 so its pretty big. Only reason I ask is cause' I don't want to drill a hole in the firewall to make my own grommet if I don't have to
Old 06-05-2010, 09:41 PM
LCAM-01XA's Avatar
LCAM-01XA
You got a slushbox trans? If so you can drill the plate that covers the hole cut in the firewall for the clutch master cylinder pushrod, or just remove said plate and install a grommet in the hole it covers...
Bronchole
07-11-2012 05:33 PM
bismic
07-02-2012 02:55 AM
Lonzom10
6.4L Power Stroke Diesel
06-14-2011 10:01 AM
bismic
05-25-2010 08:41 PM
Wheels
1999 to 2016 Super Duty
07-07-2003 05:08 PM
Quick Reply: Good place to run power inverter cables?
