Mark VIII suspension in 56 F100 - Ford Truck Enthusiasts Forums
Old 06-04-2010, 06:13 PM
Reginald56 Reginald56 is offline
Reginald56 is starting off with a positive reputation.
I was wondering if anyone on here has ever used a Lincoln Mark VIII front and rear suspension on a 53-56 F100 truck? I have found plenty of other swaps done but have yet to find this one. Any ideas why it is not used if no one has done it?
Thanks.
Old 06-04-2010, 07:50 PM
ralphhood3 ralphhood3 is offline
ralphhood3 is starting off with a positive reputation.
Can't help you with the front suspsension although there are folks on here that have done the front. I'm in the middle of installing the Mark VIII IRS in my 53 right now, should be finished tomorrow. I used the bracket kit from truckIRS.com and it's amazingly easy if you can measure accurately. Dave Held from their site has been extremely helpful in answering my questions before I purchased the brackets and any that have come up since then.
If you look for posts over the past couple weeks in this forum there's a thread on the MarkVIII swap with info from a couple other people that have done it as well, a couple people have done it with the same brackets I'm using and others have completely fabbed the install themselves.
The one thing I'm trying to figure out now is gas tank location. I want to do something that's not in the cab or under the driver's seat outside the frame rail (like the 53 is stock), and the typical mustang tank folks use I don't think will fit in the rear rails of my truck with the Mark VIII IRS installed since the mounting crossmember of the IRS sits so far behind the rear axle. I'm hoping to figure out some other gas tank install that'll fit between the frame rails, but depending on whether you're planning to relocate your 56 in cab tank you may want to consider that before putting the IRS in your truck.
Ralph
Old 06-05-2010, 09:38 AM
55 f350's Avatar
55 f350 55 f350 is offline
55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold
look up mytbtruk / larry's build . he used a 95 thunder bird for the donor front and rear , and the thunderbird , cougar , and mark 8 are all the same car underneath except for the bags the lincoln has . also look up a thread by jeff and nichole as just about everyone using it has posted in that thread . later
Old 06-05-2010, 11:29 AM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Ralph,
have you considered using a 56 panel truck tank? It fits inside the frame rail under the truck.
Old 06-05-2010, 11:41 PM
AxRacer, hadn't considered the 56 panel gas tank or even seen one before. I'll have to look into it and see if it'd work for me.
Thanks for the tip!
Ralph
Old 06-06-2010, 01:37 AM
I saw someone who said they were using a jeep tank.
Old 09-18-2010, 11:36 PM
J2Davis J2Davis is offline
J2Davis is starting off with a positive reputation.
I have purchased the 8.8 IRS from a 97 Mark III and am planning the install in my 56 F100. I wanted to mount the tank between the frame rails but realized it may not fit. I'll be interested in hearing what others end up doing.
Old 09-19-2010, 11:27 AM
Old F1's Avatar
Old F1 Old F1 is offline
Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.
bump up to the top.
J2...... in most cases tagging on to an older thread sometimes gets missed, if you get no satisfaction try posting a new thread.
F100 Electrical 99blkrk 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 09-16-2016 09:28 AM
F100 with 4.6 DOHC MARK VIII fuel pump question. bjmayberry2 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 10-06-2015 08:42 AM
Mark VIII fan JB78f150 1973 - 1979 F-100 & Larger F-Series Trucks 11 01-19-2012 08:42 PM
Mark VIII vs. CV Osiyo59 1961 - 1966 F-100 & Larger F-Series Trucks 8 08-27-2011 11:43 PM
Source for Mark VIII IRS Lowered Coil Springs? ralphhood3 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 06-03-2010 01:20 PM
Tags
1967, 56f100, f100, ford, forum, ifs, install, installed, irs, lincoln, mark, mk, rear, suspension, truck, viii
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
