EGR gasket??
Man, I wish I wasn't on vacation! I have those packages in my file at home. It isn't a gasket that I envisioned, it's this very thin metal gasket, kinda like the gasket that is in the EGR valve kit. It is also the same as the gasket that is at the top of the up-pipe. You know, the one with the "tabs" on it.
on
If you lost the gasket check on top of the trans they like to land there.
Tip: to hold the gasket in place durring assembly smear vaselin or trans gel on the side you are going to put to the egr cooler.
If you are after the V-band clamp. you would have to ask for the mormon clamp between the egr cooler and adapter pipe.
I just suck with part numbers.
Great to have you on this forum cheezit! Thanks for being here.
Sean
on
fin1
11-26-2008 08:12 PM
79 bronc
03-14-2008 08:06 AM
