Transmission Range Sensor - Ford Truck Enthusiasts Forums
Old 06-04-2010, 11:07 AM
wmcvetty wmcvetty is offline
wmcvetty is starting off with a positive reputation.
I have a 95 ford explorer sport that has been giving me issues starting to the point that I had to move it to neutral, then sometimes reverse before it would start. I am told that matches the symptoms of the transmission range sensor going out.
I have the part, and I have gotten all but the center nut off, and man it is not budging. Any time I try to move it the manual shift lever pops gears on me. Is there a way to lock that down so it does not move while I losen the nut?
Thanks,
Walter
Old 06-04-2010, 02:32 PM
Well, leaving the shift cable on did not do it! Now I need to replace that stupid thing - they tend to break if you put to much pressure on them .
For the record, I put it back on and then went back out and forgot that I had done so. I was reminded quickly as I heard an strange snap. Followed by a few choice words.
Of course, the transmission shift cable is a dealer only item, or junk yard.
2004 Explorer automatic transmission will not engage hdel Explorer, Sport Trac, Mountaineer & Aviator 3 01-06-2015 10:39 AM
04 f350 6.0l got some shifting issues forge1992 1999 to 2016 Super Duty 11 04-23-2013 10:22 PM
ABS speed sensor ohms ??? BadDogKuzz 1999 - 2003 7.3L Power Stroke Diesel 1 04-28-2011 08:14 PM
Error Codes Shift Solenoid B, Range sensor malfunction Vladimier 1997 - 2003 F150 13 04-03-2011 05:57 AM
01 Ranger 4X4 Transmission Problem bryan82 Ranger & B-Series 10 04-11-2008 11:38 PM
Tags
150, 1994, 1996, 2000, 2003, 2005, expedition, explorer, ford, part, range, sensor, switch, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
