Homemade oil change sticker - how to? - Ford Truck Enthusiasts Forums
General Automotive Discussion
Old 06-03-2010, 06:08 PM
spikedog's Avatar
spikedog spikedog is offline
spikedog is gaining momentum as a positive member of FTE.
I like to change my own oil, but would like to make my own window reminder stickers. What the best way to do this? Will ordinary scotch tape turn yellow and leave a snail track of goo on the windshield? Perhaps these are available from a store or internet supplier?
Old 06-03-2010, 06:25 PM
dchamberlain's Avatar
dchamberlain dchamberlain is offline
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
Here is a possibility. There are only 6 per package. I just searched Amazon, you might try a Google search for more options.
Amazon.com: Dorman 65287 AutoGrade Oil Change Sticker: Automotive
Old 06-03-2010, 07:02 PM
GLR's Avatar
GLR GLR is offline
GLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputation
I usually write the date and mileage on the oil filter, and on a door jamb sticker which I record the things done. A log book could also be used. If you know anyone that changes a lot of oil they might give you some.
Old 06-03-2010, 07:39 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
I always write date, miles and what was done in the back of the owners manual. Of course now 11 years and 250K miles later the back of my owners manual is now full of dates and info.
Old 06-03-2010, 07:45 PM
LMS Residential's Avatar
LMS Residential LMS Residential is offline
LMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputation
I wish I could be that organized. Usually I just write directly on my workbench in the shop date/mileage info. If I ever had a disputed warranty related failure, guess I'd have to haul the bench over to the dealer along with scrunched up oil receipts.
Old 06-03-2010, 08:03 PM
ArdWrknTrk ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
I slap a piece of blue masking tape on the door jamb near the data plate.
I just write the date and mileage with a Sharpie.
I almost always do a chassis and driveline lube while waiting for the oil to finish draining.
Annual tune up includes air and fuel filters, fresh plugs, cap & rotor.
I purge the brake system with a quart of fluid, change the plug wires and check the timing every couple of years.
Old 06-03-2010, 08:13 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
Heck, many parts stores have rolls of these stickers, and will gladly give a few to anyone who asks.
Using a paint marker, and writing the mileage on the filter is works pretty decent, if the filter is visible. All but one of my vehicles have a very visible oil filter (300 I6 and rotaries) so I tend to do this on those vehicles. The nissan, on the other hand, has a very well hidden oil filter. I'd have to learn to read and write braille for this idea to be of any use.......
Old 06-04-2010, 12:39 AM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
Avery #4162 labels or something in the 2" width works well. You can print what you want on them or print and hand label like a normal sticker. They remove fairly easily.
Old 06-04-2010, 03:36 AM
cjben cjben is offline
cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.
advance auto here has them hanging right by the oil rack,they are free,you can take as many as you need.
Old 06-04-2010, 09:32 AM
spikedog's Avatar
That looks like a pretty good deal. I found some Amsoil stickers for sale on the internet too. I'll keep an eye out for some at the auto supply store next time I'm in there too.
I keep detailed records of all maintenance activities on all my cars, but I keep those in the glove box in the owner's manual. I like to be able to see how close I am mileage-wise by just glancing up at the windshield without digging around. With 7 vehicles to keep running, I like to keep things simple.
Old 06-06-2010, 09:57 PM
Bruker's Avatar
Bruker Bruker is offline
Bruker has a very good reputation on FTE.Bruker has a very good reputation on FTE.Bruker has a very good reputation on FTE.
I change my oil at 10,000 intervals at or near the mileage point. It's easy to remember that way.
Old 06-07-2010, 02:42 PM
Rusty_S's Avatar
Rusty_S Rusty_S is offline
Rusty_S has a great reputation on FTE.Rusty_S has a great reputation on FTE.Rusty_S has a great reputation on FTE.Rusty_S has a great reputation on FTE.
I just use a notebook I keep in the car. Its a small two subject one. First section is for oil change and maintaince records, the second is for keeping records of miliage, gallons bought, fuel indicated in tank for keeping track of miliage.
Aside from that there are some restoration companies I know that sells universal "Ford" maintaince stickers for the door jambs. If you are interested I can get the links to the different ones and post them.
Old 06-09-2013, 10:42 AM
OilChangeSticker OilChangeSticker is offline
OilChangeSticker is starting off with a positive reputation.
I made this Online Sticker that I can setup on my mobile phone which is near me always.
I think the date and mileage at which the last oil change was done is the best data.
The form is editable, so you just change it with each subsequent oil change and save that data.
You guys can try it here:
My Oil Change Information | We Save Your Oil Change Information for you.
You can bookmark your page from the browser in your phone and even make it appear as an icon shortcut to your page.
Hope you like it.
Old 06-09-2013, 02:51 PM
Cigargoyle Cigargoyle is offline
Cigargoyle is starting off with a positive reputation.
I write everything I do on the underside of the hood with a Sharpie.
Old 06-13-2013, 09:13 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
I use the odometer. I use a 5,000 mile OCI, so, once it's synchronized, the oil gets changes every time the odometer clicks over to a exact multiple of 5K. Don't need to write the mileage down that way...
Excessive oil consumption rock2610d Modular V10 (6.8l) 21 01-08-2016 11:20 AM
2004 Explorer Transmission fluid change, need help shadylemon1 Explorer, Sport Trac, Mountaineer & Aviator 24 04-25-2015 06:55 PM
Oil change: go with the sticker or the internal monitor? lwk362393 6.7L Power Stroke Diesel 21 04-20-2015 12:01 AM
Supercab Door Sticker Raymond 1999 to 2016 Super Duty 4 03-19-2015 08:04 PM
Differential fluid change ChefJeff1 1987 - 1996 F150 & Larger F-Series Trucks 9 03-02-2015 08:50 PM
Tags
95, auto, change, ford, make, mileage, oil, paint, parts, record, sticker, stickers, stores, strip, truck, write
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
