1998 Dodge Ram - NO SPARK - Ford Truck Enthusiasts Forums
General Automotive Discussion
Old 06-03-2010, 06:02 PM
phix's Avatar
phix phix is offline
phix is starting off with a positive reputation.
This is my last non-ford truck and it's going up for sale, however I can't sell it until it starts!
1998 dodge ram 2500, 5.9L V8, 4X4, automatic
Last week I started it but it revved very high (throttle cable stuck) so I turned it off figured I'd deal with it when I had more time. Went to move it today and it turns over but won't start - no spark. I have since replaced the ignition coil and cap and rotor. The fuel pump does engage and the ASD is functioning correctly. Any ideas, any input is always appreciated.
Thanks,
PHIX
Old 06-05-2010, 01:37 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Can`t be much help other than to suggest you check any ground wires around top of engine and any from engine to frame and body.
Old 06-06-2010, 02:18 AM
ford2go's Avatar
ford2go ford2go is offline
ford2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud of
There's probably a hall effect sensor in the distributor to trigger the spark.
Also, some mopars have crank sensors.
You might try allpar.com or one of the other mopar forums. ( I think that there's a dodgetruck.com)
Old 06-08-2010, 10:25 AM
phix's Avatar
It's fixed, replaced the crank sensor. Thanks for the leads.
PHIX
Ford expedition service manual Download?? cableguy1224 1997-2006 Expedition & Navigator 27 02-18-2017 09:05 PM
1996 Ranger Automatic not Shifting phix Ranger & B-Series 4 01-14-2016 09:17 AM
Epic Dodge Fail Turns Into Comeback Victory for the Ages AdPock 1999 to 2016 Super Duty 5 08-01-2015 12:25 PM
1998 Ranger 4.0L Won't Start gateway1 Ranger & B-Series 2 11-05-2014 09:14 AM
Tags
1996, 1998, 2500, 37, 50, 98, coil, crankno, dodge, pickup, ram, spark, start, v10, w2500
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
