Truck shaking viently after hiting a bump
What year is your truck? When did it start? Have you done any repairs etc.. recently? Do you have a lift? I am guessing it is an '05-'07...
It sounds like you have the Death Wobble.
Go grab a beer or twelve, search the forum for "Death Wobble" and start reading... There seems to be many causes with many solutions with no real answer.
Next to check is for blown/bad shocks, big shake at 65 mph.
Good luck
If you do a search for "death wobble" you will find a million posts on the subject.
"Typically" with the 05 and up. This is a known problem with the coil suspension front ends and equates to improperly designed steering geometry. This can happen on stock trucks as well as modified. There can be one, some or many different items/issues than can result in the death wobble. Ultimately,the issue is with the steering geometry and can most likely be cured with having the draglink and track bar parallel with each other. If you don't have a track bar drop bracket or adjustable bar my guess is that's your number one problem.
Having new shocks and stabilizer is a start. You will also benefit highly from a "professional" alignment with caster/camber shims.
What WOBBLE?
http://www.google.com/url?url=http:/...WReWU1nPvDH2BA
What WOBBLE?
Bobby Snyder
1999 to 2016 Super Duty
03-15-2017 08:48 PM
70FE250
02-11-2016 05:50 PM
dustys7.3psd
06-17-2009 01:47 PM
