89 F250 351W Timing Issue - Ford Truck Enthusiasts Forums
Old 06-03-2010, 10:29 AM
qbert qbert is offline
qbert is starting off with a positive reputation.
Question 89 F250 351W Timing Issue
My 89 Ford 250 sounds like it has a timing issue and I can not find how to set the timing on this truck. It has the fuel injected 351 Windsor motor in it. Anyone?
Also, the "check engine" light is on (could be affecting the timing). How would I find the code on this to find out what is wrong? It is obviously not OBDII.
Old 06-03-2010, 10:50 AM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
Hook timing light to #1 plug wire , pull out the spout conector , set the timing at 10 deg BTDC, replace spout.....Lew
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Old 06-03-2010, 10:55 AM
nstueve's Avatar
nstueve nstueve is offline
nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.
There is also a plenty of cheap code readers out there for cheap, like this one Equus Innova EPI 3145 OBD-1 Ford Scan Tool Code Reader at Gadgets Galore!
Also welcome to FTE... NEWBIE!
Old 06-03-2010, 11:28 AM
Thank you guys so much! You guys are great!
Old 06-03-2010, 11:43 AM
rla2005's Avatar
I need one of those readers! I get tired of counting flashes. Fortunately my '92 F350 is running like a champ right now.
Old 06-03-2010, 12:40 PM
nstueve's Avatar
i'm sure you can find them cheap 2nd hand to off craigslist (or crazedlist) and ebay...
Old 06-03-2010, 12:42 PM
nstueve's Avatar
you can also go to oreilieys and have it done for free too... they'll give you a print out of the results.
Old 06-03-2010, 12:52 PM
OK, so back to the timing...how do you go about actually setting the timing? Do you have to loosen a bolt on the distributor? Can this be done with the cap still on it? How do you read the light? The mechanic I took the truck to originally said that I could not set the timing on my truck because the computer sets it...meaning that the distributor could not move. Not sure of the validity of that statement, but I figured that most of the 351W's were pretty much the same. Im just not knowledgeable about cars to set the timing on my own without a little guidance. I dont know what to move and what to aim the light at or read the light for that fact. LOL
Old 06-03-2010, 01:03 PM
rla2005's Avatar
Old 06-03-2010, 01:15 PM
Right, I get that...but the lingo is difficult for me to comprehend. Heck, I dont even know where the harmonic balancer is. LOL From the diagram, it looks as if it is attached to the distributor...which does not move on my truck.
Old 06-03-2010, 01:26 PM
rla2005's Avatar
Incorrect. The distributor does move on your truck. The base timing is set by removing the SPOUT connector, then moving the distributor. You use a timing light to verify the distributor is properly set. Once you do that, put the SPOUT back in. The computer does control the timing with that SPOUT plugged in.
Your mechanic is not helping you any by making misstatements like they have. Find another mechanic who knows something and/or buy a repair manual to help you understand what needs to be done.
Here is another link to a technical writeup for upgrading the ignition components and bumping the timing up from factory specifications. There are some more photos and captions to help you out: ignition upgrade and timing bump
Info Request - '00 Ex v10 won't start jmh944911 Excursion - King of SUVs 8 03-13-2014 12:40 PM
Mods, Maintenance, and Life(long and kind of pic heavy) redman84 1994.5 - 1997 7.3L Power Stroke Diesel 17 05-29-2013 12:38 PM
Bulletproof Diesel Oil Cooler INSTALL -Snake- 6.0L Power Stroke Diesel 46 11-06-2012 05:33 PM
Camshaft???? RANGER589 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 18 06-03-2011 10:03 AM
Need Header Ideas-SBF(W)---'56 Effie rockher_man 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 08-07-2009 10:11 PM
Tags
1996, 351, 351w, 89, base, check, engine, f150, f250, ford, light, set, spec, timing, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
