Flathead oil prime
To expand on Ross' post, the best flathead guys are here:
Ford Flathead V8 .. 1932 thru 1953 • Index page
Did you use assembly lube on the bearings and other moving surfaces? If so you probably don't need to pre-oil. The system should be pumping oil before any damage can occur to the babbitt surfaces.
Did you pack the oil pump with vaseline before installing? If so you probably don't need to pre-oil.
Otherwise, pull the oil pressure sending unit off the back of the block and pump oil down the hole.
rustoleum82
09-02-2016 08:04 AM
BinfordToolman
1997-2006 Expedition & Navigator
09-07-2010 07:09 PM
onewaymike
11-30-2002 02:02 PM
