79 f700, clutch replacement - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 06-02-2010, 04:37 PM
79 f700 370 2v 79 f700 370 2v is offline
79 f700 370 2v is starting off with a positive reputation.
I will be replacing my clutch in my 79 f700 dump 5 speed, split rear, 370 lima 2v.
I will be doing the clutch this weekend, the clutch is weak and starting to slip and smoke, truck still drives but only tops out at like 50 mph, plus clutch does not disengage until pedal is almoust all the way out, its not the adjustment its defenatly the clutch
I guess im just looking for some instuctions or any tips you guys might have
thanks for lookin
Old 06-02-2010, 04:41 PM
i guess i will be replacing the throwout bearing too, because the new clutch comes with the new throwout bearing
Old 06-03-2010, 11:47 AM
1960fordf350's Avatar
1960fordf350 1960fordf350 is offline
1960fordf350 is starting off with a positive reputation.
If the rivets from the clutch have eaten into the flywheel, you'll have to get it turned. Checking the pressure plate also for gouges. The pilot bearing in the back of the crank probably should get changed too. Its a roller bearing type, not a bronze bushing like on smaller vehicles.
Old 06-03-2010, 01:25 PM
Redcat Diesel's Avatar
Redcat Diesel Redcat Diesel is offline
Redcat Diesel is gaining momentum as a positive member of FTE.Redcat Diesel is gaining momentum as a positive member of FTE.
Hope you have a trans jack cause that 5 speed is a bit too heavy to lift by hand. Once the trans is out and the inspection plate is removed you should be able to drop the clutch thru the bottom without having to pull the bell housing. If you unbolt the shift lever you can use a bungie cord to hold it up rather than removing the boot to pull it totally out.
1979 F-700 Clutch linkage bushings lterrip 1973 - 1979 F-100 & Larger F-Series Trucks 0 04-16-2015 12:24 PM
Transmission Trouble in my '79 F700 lterrip Large Truck 8 04-04-2015 05:33 PM
GCWR of F700 Wes(MI) Large Truck 3 02-14-2015 03:19 AM
my f 700 will not run right, help please 79 f700 370 2v Large Truck 2 05-17-2010 10:13 PM
F700 & f600 enegine swap?370 swap to 391 will it work? ddsprint Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 06-27-2008 08:44 AM
Tags
1997, 60, 700, adjustment, bearing, clutch, clutches, diesel, f700, ford, forf, removal, series, throw, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
