Cigarette lighter install
#31
Well, I was wrong. I don't know what the little piece that feels like the end of a broken wire is, but neither wire was broken or disconnected.
Now I have the spade connector loose but can't get the boot one off, nor get the spade back on.
It looks like corrosion in the lighter is the problem - if I knew I could get the spade back on, I'd try sandpapering the rust off.
It would be a whole lot easier if I could get the whole unit out so I can see what I'm doing. There's not enough space between the ashtray and the hump (4-speed manual tranny) to get my head in there, and I don't have a small mirror.
Help! I need to go to town and HAVE to take my dogs, but I can't leave them in the truck without the 12v fan that plugs into the lighter!
How do I get the unit out??? I can't see or feel any screws, except for the whole ashtray assembly. It looks like the lighter housing should just slide out. Does it? Do I just need some WD40?
#32
Well, mine didn't have one in place, so I'm not sure how the stock lighter comes out, but it may be the same as the aftermarket unit. If you look at the one I posted, the outer sheath with the ribbing on it unscrews. You can barely see at the back of the lighter that there are threads there. The whole outside unscrews from the assembly. The sheath comes off the back, and the guts of the lighter just slide out the hole. It may be easier to see if you take the ash tray off so you can flip it over and see what you're doing.
#33
I don't see an outer sheath, just a black box the inner (I presume) sheath is in. I can get the inner to turn a little, but not much with the boot connector still on. Does it pull off or unscrew?
I think your idea of just taking the whole ashtray out is probably what I'll have to do.
Thanks again. Glad you're here!
#35
#36
re ashtray & lighter removal
Thanks!
#40
Installation of Sirius Radio Dock
I ran a new cigarette lighter adapter in my daily driver when i got it (2005 mazda 6). it's pretty easy. just pickup the cigarette lighter kit at the auto parts store and run the red line to your fuse box and ground the black cable somewhere near the lighter. The autoparts store lighter kit might not allow for actual cigarette lighting, only for power devices such as an ipod though.
let me know how you make out. on my to do list is install my satellite radio dock in the truck and i want to run a separate lighter for that so i can still use the cigarette lighter for something else when it comes up, plus i don't like the looks of wires all hanging around.
Frmnsal
15
05-28-2018 04:04 PM
jayhawk714
1999 to 2016 Super Duty
09-27-2017 09:59 PM
vidaliaman
01-02-2017 09:02 PM
Tomget
07-24-2016 09:29 PM
