Cigarette lighter install - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 06-16-2010, 05:14 PM
Loribelle Loribelle is offline
Loribelle is starting off with a positive reputation.
Well, I was wrong. I don't know what the little piece that feels like the end of a broken wire is, but neither wire was broken or disconnected.
Now I have the spade connector loose but can't get the boot one off, nor get the spade back on.
It looks like corrosion in the lighter is the problem - if I knew I could get the spade back on, I'd try sandpapering the rust off.
It would be a whole lot easier if I could get the whole unit out so I can see what I'm doing. There's not enough space between the ashtray and the hump (4-speed manual tranny) to get my head in there, and I don't have a small mirror.
Help! I need to go to town and HAVE to take my dogs, but I can't leave them in the truck without the 12v fan that plugs into the lighter!
How do I get the unit out??? I can't see or feel any screws, except for the whole ashtray assembly. It looks like the lighter housing should just slide out. Does it? Do I just need some WD40?
  #32
Old 06-16-2010, 05:18 PM
phurst's Avatar
phurst phurst is offline
phurst is starting off with a positive reputation.
Well, mine didn't have one in place, so I'm not sure how the stock lighter comes out, but it may be the same as the aftermarket unit. If you look at the one I posted, the outer sheath with the ribbing on it unscrews. You can barely see at the back of the lighter that there are threads there. The whole outside unscrews from the assembly. The sheath comes off the back, and the guts of the lighter just slide out the hole. It may be easier to see if you take the ash tray off so you can flip it over and see what you're doing.
  #33
Old 06-16-2010, 05:37 PM
I don't see an outer sheath, just a black box the inner (I presume) sheath is in. I can get the inner to turn a little, but not much with the boot connector still on. Does it pull off or unscrew?
I think your idea of just taking the whole ashtray out is probably what I'll have to do.
Thanks again. Glad you're here!
  #34
Old 06-16-2010, 05:38 PM
How many screws are there holding the ashtray in? I found one, actually a nut. It would help to know how many I"m looking for.
  #35
Old 06-16-2010, 06:13 PM
phurst's Avatar
On mine, I had to take the dash piece off that covers the radio and HVAC controls. There was one screw holding in the ashtray. And then it slid out of place.
  #36
Old 06-16-2010, 06:19 PM
re ashtray & lighter removal
Quote:
I don't think I have to take the other stuff off - the one screw/bolt is visible at the top of the ashtray.
Thanks!
  #37
Old 06-17-2010, 01:38 PM
How does that boot connector attach? Is it a pull-off, or a screw type, or something else? I can't get it to budge.
  #38
Old 06-17-2010, 01:40 PM
phurst's Avatar
it just pushed on/pulls off.
  #39
Old 06-17-2010, 03:16 PM
Thumbs up cigaretter lightr connectors
Thanks. Now I'll try pulling harder.
Cigarette lighter installation ideas Frmnsal 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 06-23-2016 01:57 PM
Rewire cigarette lighter / power port to only come on with accessory AbandonedBronco 1978 - 1996 Big Bronco 1 02-02-2016 12:43 PM
Cigarette lighter Wolverine94 1987 - 1996 F150 & Larger F-Series Trucks 14 04-29-2012 11:55 AM
1997 F-250 LD power outlet / cigarette lighter ten70man 1997 - 2003 F150 1 11-11-2010 01:12 AM
cigarette lighter fuse blowing!! 5.4f250sd 1999 to 2016 Super Duty 9 11-10-2010 09:45 PM
Tags
150, 1978, 1980, auto, cigar, cigarette, duty, expdition, f250, ford, installing, lighter, parts, super, truck, victor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
