2001 f250 won’t go past 55
I have an 01 f250 that’s won’t go past 2.5k rpms when driving and won’t go past 55. It’s very slow and looses almost all power while driving. Any ideas, I have changed the cam sensor, fuel filter, oil pressure sensor, valve cover gaskets, fuel pressure sensor, checked fuses and other things I thought it was.
The following users liked this post:
And when you changed the engine sensors and control items, did you use OEM from the Ford or International counter guy?? If you got them from almost anyone or anywhere else you got junk. There are only a few online sources and Fleabay, Cramazon, or even the corner store are not it.
Also what was the reason for changing all the parts?
Get FORScan or FORScan Lite and the adapter they tell you to get and do some diagnostics. Look on this site for more information on using the program.
Get the cat pressure tested. I wish I did it from the beginning when I read all these forum posts saying the cats were the problem. If you are like I was, you tried all the cheaper options first, and none of the, made a difference. The test is cheap to help rule things out. It was my cat. I bought an AP/Eastern direct fit off Rock Auto for the best price. Exhaust shop installed it for free (kept old cat for scrap money). Fixed.
OBS_F-250
08-12-2021 05:24 PM
spicolas
03-15-2013 10:11 PM
spicolas
1999 to 2016 Super Duty
03-15-2013 04:07 PM
