Michigan Chapter Join Chapter, Leader: Toyman
Kalamazoo needs help
Old 02-04-2003, 09:54 AM
Tetchy101's Avatar
Tetchy101
Tetchy101 is offline
Anyone have the time or the inclination the help a Bronco owner do some Repairs........
I have a water pump that needs to get changed............
Thought Id do Timing Chain and Gears, and fuel pump.
Im going to Rebuild my Carb this weekend....needs it after sitting most of its life.
1985 Bronco XLT 351 4Brl Holley
The Truck is driveable, I wouldnt be able to sell it if I wanted to, so thats fine.....just things I need to do.
The crappy thing is that I live in an Apt...so no Garage.....I need some assistance from the amateur experts or the retired ones.
Tim
269-352-4901........if you have any advice
Old 02-06-2003, 06:46 PM
walkhaulsey's Avatar
walkhaulsey
walkhaulsey is offline
Did you find anyone to help you?
Old 02-08-2003, 08:32 PM
Tetchy101's Avatar
Tetchy101
No not yet..........But right now IM in a mess with something else....I just rebulit the carb...went together great....stuck it on the truck.....started after about 5min and a battery jump. But going down the road it would die when I stepped on the gas to run it through....when I let off the acclerator...the engine would start again......pinpointed the accelerator pump and found the rocker not working.....pulled the carb again R-squared the diaphram once more.....5 seconds after the carb was running...... accelerator pump froze up again....Im stumped.
Tim
Old 02-09-2003, 08:34 AM
tellico racing's Avatar
tellico racing
tellico racing is offline
I noticed you have posted a couple questions in the fuel systems forum. I would post the symptoms you describe above in that forum. they can figure it out im sure.
Old 02-09-2003, 08:36 AM
walkhaulsey
It would probably be easier to just buy a new or rebuilt carb. I am having the problem with my carb cutting out when the lead is dropped on the pedal.
Old 02-09-2003, 10:14 AM
Tetchy101's Avatar
Tetchy101
Here's the deal...Get up this morning, buy a gallon of gas. Start my bronco up....found fuel pump working quite well. Hooked up to carb....started up fine. Test drive....worked great. Last night I used some compressed air and blew out my accelerator pump BB and must have un-stuck it......I never thought it would have worked but it did. Now my curb Idle is the problem.....running about 250rpm too much.....but Im not complaining just yet.
Thanks for your posts.
Tim
seans79bronco
02-14-2016 10:28 PM
darkpurp1e
1978 - 1996 Big Bronco
02-20-2011 09:35 PM
92mnfordtrk
44
10-11-2008 01:15 AM
RyanGruhn
27
08-25-2008 03:28 PM
jwtimme
04-30-2004 07:26 AM
Quick Reply: Kalamazoo needs help
