intercooler all done, final product pics
alright well im a little late on posting these up, but here they are. deffinetly put the boots and clamps on the intercooler before installing, that was a pain! it was fun, i got lazy and didnt feel like grinding off every weld, so some are ugly but it got the job done. it has a cool new whistle/whine noise when pulling 6-15lbs of boost too. i lost about 4lbs but it pulls harder now and stays real cool. 1200 is challenging and stays at 1100 going up a 5% grade pulling 6lbs of boost and a steady accel and a loaded bed. around town driving can work against you if your really shifting the gears and in traffic but on the highway is were you see the greatest results.
I got it from my cusin rich (foxracing) which got it from flee bay, but yeah iPhone cameras aren't the best!
And I had a design change on the ypipe, the original was a pig to line up, I happened to stumble apon the pice of pipe I cut off the cooler pipes from the superduty fit on the perfectly almost like it was ment to be! But the original ypipe has a ton of fill to mate the 3" 90 degree elbo do to the oval shape
i like the custom intake spyder...very nice...
my only input and i cant tell from your camera angles is to brace up the "HOT" IC pipe so there isnt so much stress on the intake plenum rubber boots or the Boost pressure and rocking cause it to pop.....other than that awesome man!!!!!!!!!!!!! maybe weld a brace from that to the cold pipe.....
Looks like it should work just fine. A couple of my welds aren't great either as a couple of my pieces were aluminum. I had to have a shop weld those and didn't want to grind them down. Worried I'd grind too much off. It looks like your hot pipe hits the ac. Mine was real close too so I put some exhaust wrap around it so if it did hit it would protect it some plus keep the heat in. Just a thought
