head port and polish - Ford Truck Enthusiasts Forums
Old 06-02-2010, 06:34 AM
dean scrooby dean scrooby is offline
dean scrooby is starting off with a positive reputation.
hey, i was just wondering if any of you guys have done your own p and p job? i dont really know what the porting part of it means, and if i would be able to do it myself? any info would be really helpful. thanks
Old 06-02-2010, 08:05 AM
oldbrokecowboy oldbrokecowboy is offline
oldbrokecowboy is starting off with a positive reputation.
" Use the search box, Luke". as in feel the force. lol. The search function is your friend and is not difficult to use. Give it a try. When you;ve exhausted that reading, and pictures you will know much more. If you still want to p&p your own head I would suggest getting a junk head from the wrecking yard to practice on. One can get carried away. There are many here that have p&p thier own and I'm sure will give advice. Good luck, keep us in the loop. OBCB
Old 06-02-2010, 10:58 AM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is online now
AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.
YouTube - CYLINDER HEAD REBUILD - VALVE JOB AND PORT & POLISH ON DVD
A pretty informative (yet short in comparison) YouTube video of the procedure.
Old 06-02-2010, 01:30 PM
91Bronc300 91Bronc300 is offline
91Bronc300 is starting off with a positive reputation.
Rather than being slow and deliberate the guy seems like he just sticks his die grinder in there, turns in on, and starts wagging it around. The last port he does seems a little more controlled but the first one was all over the place LOL. Informative, but I'm glad the guy is not a dentist.
Old 06-02-2010, 01:46 PM
Yeah, if I do it, I'm definitely going slow and taking my time. The video's good for showing just what a P&P is and what it entails.
Old 06-02-2010, 03:11 PM
coolguy1419's Avatar
coolguy1419 coolguy1419 is offline
coolguy1419 is starting off with a positive reputation.
Watch lots of videos, they are the best place to start. They have kits from summitracing that you can buy to do it. If you do it yourself be prepared its gonna take awhile. I had about 10 hours in mine altogether.
Old 06-06-2010, 05:27 AM
Rust is too a color's Avatar
Rust is too a color Rust is too a color is offline
Rust is too a color is starting off with a positive reputation.
I decided to try my hand at it yesterday. Wasted about 6hrs using a variety of grinding stones chucked up in my drill. When I found my Dremel, everything changed. I quickly wore down a barrel shaped grinding stone but with promising results, so I went and got a carbide barrel bit ($12). Everythings smoother but still rough, and there are hard to reach areas. I had to build up some nerve getting anywhere near the valve seats though. Not entirely looking forward to hitting it with numerous lighter passes and I did question just paying to have it done vs my time. But at least I can say I tried it. My Dremel also never leaves the slowest speed.
Old 06-06-2010, 11:33 PM
F-250 restorer's Avatar
F-250 restorer F-250 restorer is offline
F-250 restorer has a good reputation on FTE.F-250 restorer has a good reputation on FTE.F-250 restorer has a good reputation on FTE.
Quote:
Blow out the guide and wipe off an old v. and put it in to protect the seat as you work in chamber.
No power to auxiliary power ports Dmoe512 6.7L Power Stroke Diesel 8 06-29-2014 10:23 AM
Auxiliary Power Port TheRifleman Electrical Systems/Wiring 7 01-20-2014 01:34 AM
HELP Single Port Degas Bottle Install fordsd350 6.4L Power Stroke Diesel 2 09-29-2013 06:40 PM
what port on the HPOP to hook pressure gauge to? wildstang 1994.5 - 1997 7.3L Power Stroke Diesel 34 09-29-2009 09:37 PM
2002 v6 po4o1 how to clean egr ports ? xclint 3.8 & 4.2L V6 2 08-07-2008 01:29 PM
Tags
300, 49, 49l, 73, 75, cylinder, diesel, engine, ford, head, heads, polish, port, porting, ports, truck, video
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
