Reverse lights - Ford Truck Enthusiasts Forums
Reverse lights
Old 06-01-2010, 10:24 AM
wreckinball's Avatar
wreckinball wreckinball is offline
wreckinball is gaining momentum as a positive member of FTE.
Reverse lights
Fellas,
Can someone give me a wiring diagram as to the rear lighting. My reverse lights dont come on. Looking at the thread with the favorite mod of bright reverse lights i think i might do that as well while i am under there. But for now i would like to get them working. Everything else works, just not the reverse lights. Thanks!
Old 06-01-2010, 12:01 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Can`t help with a diagram but what you should have is a combined neutral safety switch and rev light switch mounted on the outside of the C6. With the running lights on you should have 12v at one of the wires at that switch. Then with the shifter in Reverse you should have 12v going out of the switch to the rev lights.
That`s as I understand it (hate electrics).
If you have 12v to the switch but not out the switch may be bad.
Old 06-01-2010, 12:04 PM
greywynd greywynd is offline
greywynd is starting off with a positive reputation.
Doesn't matter if the running lights are on or not, the reverse lights are on if you shift into reverse. I know on a couple of mine the switch needs some adjusting, you have to wiggle the shifter a bit to get them turned on sometimes.
Old 06-01-2010, 12:29 PM
Cruickie's Avatar
Cruickie Cruickie is offline
Cruickie is starting off with a positive reputation.
Doesn't seem want me to add the picture to the thread for some reason but there is a picture for your trucks (1989 Ford Truck F 350 4WD Pickup V8-7.3L DSL) back-up light diagram at the following link (in my album):
Ford Truck Enthusiasts Forums - Cruickie's Album: 1986 F250 XLT Lariat - Picture
Hope that helps!
Old 06-01-2010, 01:35 PM
So what would be the best way to determine if the nss is bad? Can i just poke through the wires and see if i get power when it is in reverse? Any idea on the color of the wire that goes to the reverse lights from the nss? I know the colors are good so no franken truck issues there! lol
Old 06-01-2010, 02:25 PM
RCrawler's Avatar
RCrawler RCrawler is offline
RCrawler is gaining momentum as a positive member of FTE.RCrawler is gaining momentum as a positive member of FTE.
Quote:
At the switch:
Should have key on 12V at the Purple/Orange wire
12V through switch when in reverse at the Black/Pink which feeds the back up lights.
Jason
Old 06-01-2010, 02:32 PM
David85's Avatar
David85 David85 is offline
David85 has a good reputation on FTE.David85 has a good reputation on FTE.
There are quick connects close to the NSS. First isolate which wires are for the NSS and which are for the reverse lights - 2 for each.
Then you can do a simple continuity test between the exposed connection tabs to see if the switch is working. Probing the wires will also work but considering the amount of sand and salt those wires get exposed to in the winter, I would avoid doing that.
No Reverse lights WildMav 1987 - 1996 F150 & Larger F-Series Trucks 3 01-10-2017 01:48 PM
95 f250 reverse gear problems Sam's The Man 1987 - 1996 F150 & Larger F-Series Trucks 5 03-06-2016 07:28 AM
1987 F350 Reverse lights troupstree 1987 - 1996 F150 & Larger F-Series Trucks 12 07-07-2014 11:17 AM
Reverse lights don't work on 71 f100 400 v8 Stang Thang 1967 - 1972 F-100 & Larger F-Series Trucks 28 10-23-2012 08:20 PM
94 F250 - No reverse lights! Pharticus 1987 - 1996 F150 & Larger F-Series Trucks 9 01-18-2012 06:42 PM
Tags
1989, 1994, 73, backup, c6, diagram, dont, f150, ford, idi, light, lights, reverse, switch, wire, wiring, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
