The wrong harmonic balancer?
Ok, I checked the #'s for my balancer and it's a 28oz. My engine is a 1991 302 with a few perfomance parts ie. RPM Performer heads & Edel. 2 x 4 intake & MSD ignition. It's mated to a t-5 also.
I got the engine as is from the previous owner and just fired it up recently and found the timing marks to be nowhere near the pointer. While determining true TDC I thought I'd verifie the balancer being correct,
So my question: is there any reason to use a 28 oz. balancer instead of the 50 oz.
Thanks in advance for your input, David
It's possibly if the engine was replaced that someone grabbed a older one....
The 28ox balancer, crank, and flywheel/flexplate are a combo. They aren't supposed to be mixed and matched...
The engine ID# indicates 1991 t-bird. The PO got the engine in a mustang he planned to drag race but decided to replace it after a short time with a stroker. The engine has been rebuilt.I've had the oil pan off and checked the rod & main bearings. They are marked standard and the crank has #E7AE-AA on it. The pistons are TRW (on the bottom) supposed to be 10 over? The cylinders still show the cross hatched patern and the pistons and rods show the grinding & drilling signs from balancing.
I purchased the t-5, along with all the necessary parts to install it ie. bell housing, pedal assembly, driveshaft, new flywheel etc. The flywheel is 157 tooth which I understand to be the 50oz. I'm pretty sure the PO had the engine hooked to an automatic trans.
Am I safe to just install a new 50oz. balancer and not worry about it?
By the way this engine is going into a 32 ford roadster I'm building.
Thanks everyone, David
Casting numbers cannot be cross referenced to Ford part numbers, cannot be used to ID the size of the engine, or what it is from. Basically they are worthless.
So you are only assuming the block is from a Bird. It could be from a Mustang, Mark, Crown Vic, Grand Marquis, T-Bird/Cougar, Town Car.
The crankshaft ID number of E7AE-AA was Ford part number E7AZ6303A which was replaced by E4ZZ6303A and used in darn near every 302 from 1987 thru 2004.
NumberDummy<
I don't want to offend you or appear to not be thankfull of your help but if you go back to my original post you will find that my question is: Is there a logical reason to use a 28 oz balancer on a late 80's / early 90's 5.0 instead of the 50 oz.
I don't believe the model of car the engine came in from ford has anything to do with my balancer concern.
Thanks again for your input, David
TireDood
03-25-2015 10:03 AM
mauicruza
26
12-24-2012 08:02 AM
