You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Year: 2002 Make: Ford Model: F-250 Price: $15250 Mileage: 122000 Color: Maroon Private or Dealer Listing: Private Listing Location (State): WI Transmission: Automatic Drivetrain: 4WD & AWD Color: Red Engine: 7.3 Powerstroke
Up for sale is a 2002 Ford F-250 Super-duty 7.3 Power stroke Diesel 4x4 truck. It is the extended cab short box version. It has less than 119,000 miles on it! I've upgrade pretty much everything on the truck. The transmission has a Greg Evans valve body installed (with fresh filter and fluid), removed the stock air intake and installed a RiffRaff 6637 filter with filter cover, at the same I did the CCV delete and re-routed it down the driver side frame rail. I have installed the A-pillar gauge pod with 3 Glo-Pro gauges (trans temp, EGT, boost). Also has a leveling kit (rear add-a-leaf for towing). A fifth wheel hitch (hide-away) set up in the bed. The turbo has an EBPV delete mod, as well as a wicked wheel installed (spools faster). Ranch-hand front bumper (heavy duty!). 4" exhaust from turbo back (no muffler). Just did a oil change, fuel filter, and rear diff fluid. The truck has like new 285/75/16 Nitto Grappler tires on stock wheels. It also has factory matched window tint on front two windows and 5% on the front banner. There is a CB radio installed. I do have a Kenwood NAV/DVD player installed that is not included (stock radio will be installed unless wanted to bargain a price). The truck has been used, there are scratches and dents. The only spot of rust is shown below (driver's side rear wheel well). The transmission has a seal that needs to be replaced on the gear shift selector. It's a $5 part, but I need a special tool to remove the selector shaft. Local trans guy said it would run $100. If this is a problem I will have it repaired for the right deal. Other than that, no leaks, everything works (heat a/c, all power options, ect). This truck sounds great and runs even better! Must see it and drive it to believe. I've added a video to show how it runs!! Feel free to ask questions or need more pictures. Also mileage will increase as I continue to daily drive it. All sales final, sold as is where is. Thanks for looking! * Also I have had people ask about the leak and the driveway below the truck. That is not from this truck!! The transmission doesn't leave a mark on the drive way when parked overnight. (I've had many project vehicles parked there... I apologize for the confusion!)
