Fuel gauge problem - Page 2 - Ford Truck Enthusiasts Forums
Fuel gauge problem
Old 12-23-2010, 09:14 PM
Derfus's Avatar
Derfus Derfus is offline
Derfus is starting off with a positive reputation.
I've done some searching and havent ran across this same problem. My fuel gauge works but only half way. If I fill up the tank it will show a little above half a tank. When it's empty (or as close to it as I'm brave enough to run it) it's below the "E". So the gauge works... just not quite like it should. The fact that it doesnt work right drives me nuts. Any ideas from the pros?
Old 12-24-2010, 05:18 PM
phatjack81's Avatar
phatjack81 phatjack81 is offline
phatjack81 is starting off with a positive reputation.
It could be that the brass float has a small leak and fuel has got inside of it. Or maybe the sending unit came loose inside the tank. Either way you have to drop the tank and take a look inside and that would be a good time to see if the tanks rusting where the straps hold it in place.
Old 12-24-2010, 05:35 PM
big78f150's Avatar
big78f150 big78f150 is offline
big78f150 is starting off with a positive reputation.
similar question, my gauge worked fine till about a week ago. now when i first start the truck it pegs wayyyy below e, then it will go up to the correct amount in the tank at the time, then back to below e. im lost. i did notice i have a small leak but idk if that would have anyting to do with the gauge
Old 12-24-2010, 07:55 PM
phatjack81's Avatar
Quote:
That might be as simple as a bad ground wire back at the tank The leak won't have anything to do with the gauge but definitely fix it.
Old 12-24-2010, 08:49 PM
big78f150's Avatar
didnt think it was. gonna take it to the radiator shop and have them clean it and seal everything. and was gonna put a new sending unit in the tank just cause it was out. but it gonna have to wait till it warms up some lol
Old 04-21-2014, 11:13 AM
erik68 erik68 is offline
erik68 is starting off with a positive reputation.
fuel guage
im having same prob.fuel guage and dash lights dont work.took off the dash but there are no wires to the gas guage all the wire go to a harnes that goes into the dash cluster.what wire controls fuel guage?77 ford f100
Old 04-22-2014, 01:59 PM
Dave145's Avatar
Dave145 Dave145 is online now
Dave145 is starting off with a positive reputation.
2 things:
1. Did you check the float like what was mentioned in this thread?
2. Why tack on to a 4 Year old thread? You'll get a lot more responses if you start your own.
Old 08-18-2014, 01:46 PM
alanblueeeee alanblueeeee is offline
alanblueeeee is starting off with a positive reputation.
I need help with my gas gauge , it just sits below E never moves . Is it a bad ground ? A bad gauge ? or something in my tank ?
Old 08-18-2014, 01:56 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is online now
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Quote:
Welcome to FTE. Lot's of good people.
Does your temp gauge work okay? Temp and Fuel both use the same regulated power source (5.5 V).
If the temp is okay, crawl under your truck and unplug the sending unit. The plug has two wires going to it. One goes to the gauge, the other goes to a ground. Turn your ignition to the "on" position. Ground the wire that goes to the gauge and see what the gauge does. If the gauge and wiring are good, the gauge should swing over to Full.
If it swings to Full, then either the sending unit is bad or there is a bad ground point after the sender, check the wire and ground point, it's directly in front of the sender, on the crossmember.
If when you ground the wire, the gauge still doesn't move, you'll need to get a multimeter and start checking for power and continuity in the gauge and circuit.
Old 08-18-2014, 02:01 PM
i beilive the temp gauge works fine , but when i first bought the truck it would come on at random while driving then go away , so do you think its a bad ground ?
Old 08-18-2014, 02:17 PM
mikeo0o0o0's Avatar
I doubt it. On the temp gauge, the ground is the sending unit. Check to see if the wire that is connected to the sender is a tight, clean connection.
Other than that, do the troubleshooting that I posted above. You should be able to diagnose it.
Fuel Gauge Reads Empty - Senders OK ? Birken Vogt 1987 - 1996 F150 & Larger F-Series Trucks 5 09-18-2016 08:35 PM
1999 Expedition Fuel Guage not working jdemkowicz Expedition & Navigator 9 08-09-2016 01:01 PM
Fuel Gauge Dancing jayhenf350 1987 - 1996 F150 & Larger F-Series Trucks 1 11-02-2014 09:52 AM
Gas and Temperature Gauge Issues JD_F100 1967 - 1972 F-100 & Larger F-Series Trucks 26 08-31-2014 11:26 AM
Dreaded fuel gauge question 79F250RepoTruck 1973 - 1979 F-100 & Larger F-Series Trucks 6 03-22-2012 08:36 PM
Tags
19731979, 1977, 1995, excursion, f100, f350, fix, ford, fuel, gas, gauge, issues, truck, wiring, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
