LOCATION OF A/C LOW PRESSURE SWITCH - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 05-31-2010, 05:26 PM
dchatcher dchatcher is offline
dchatcher is starting off with a positive reputation.
Have a 2008 Expedition XLT with Rear Air and need to find the location of the A/C Low Pressure switch which appears to not be working. Can get compressor to engage by putting 12vdc on Purple wire at compressor and then unit works fine until it sits for a few hours. Have taken to dealer (45 miles drive) but it is working when I get there. Accumulator/Low Pressure Switch is not at the firewall like it is on my 2008 F-150. Anyone know were they hid it??
Old 05-31-2010, 10:38 PM
lsrx101 lsrx101 is offline
lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.
That sounds more like a clutch gap issue than the pressure switch.
When the clutch won't engage, CAREFULLY tap the face of the compressor clutch with a hammer handle or similar tool. If it engages, the clutch gap is too wide.
See the FAQ in the AC section for the steps to adjust the clutch gap.
Old 06-01-2010, 09:51 AM
Do not get the 12 volts to the clutch so cannot be the clutch. The 12 volts to the purple wire on the input connector comes thru the Low Pressure switch.
Old 06-01-2010, 06:20 PM
Yes, you can often get the compressor to engage by applying 12v directly to the clutch coil when the gap is too wide. Did you check for voltage at the coil with a meter or test lamp?
Do the tap test first before you condemn the switch. Those switches usually fail totally open or go out of range.
Old 06-01-2010, 08:13 PM
Did the voltage test with a volt meter and also made sure I have a ground to the Black/Green Stripe wire to the clutch and tapped the clutch hub before I started with the volt meter. Since I had no voltage to the clutch connection terminal, I am sure its not the clutch. They must have the Low Pressure switch back at the rear unit somewhere........
Old 06-01-2010, 09:58 PM
The switch will be under the hood and plumbed into the Low side of the front AC.
Follow the larger (suction) line from the evaporator, to the accumulator, and back to the compressor. It will be there somewhere. It is usually screwed onto a fitting on the accumulator, but I'm not familiar with part placement on your particular vehicle.
ac compressor not engaging johnj54 1968-2013 Full Size Vans 4 05-28-2016 12:14 PM
A/C low pressure switch Brooks Rowell 1999 - 2003 7.3L Power Stroke Diesel 6 06-20-2014 01:37 PM
02 f-350 no power to a/c compressor reaydanny 1997 - 2003 F150 1 07-16-2012 06:37 AM
A/C not getting cold, HELP? monkeyWrencher 1997 - 2003 F150 8 07-11-2011 10:36 PM
Air Con diag question chrisjb 1999 to 2016 Super Duty 8 05-14-2009 07:48 AM
Tags
150, 2004, 2007, ac, accumulator, expedition, explorer, f150, ford, location, low, navigator, presssure, pressure, ranger, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
