Modern Bed Bolt Swap?
I'm looking to replace the bed bolts on my 73 F-100 and am looking for potential replacements. I grabbed a bed bolt from the newer F-150s/250s, but they are round bolts vs. the carriage bolts that are standard for the 70s. Is there another manufacturer/year that utilizes a carriage bolt that would transfer over easily?
I realize I could jsut round out the carriage bolt holes in the bed, but I would rather not do that if I had to.
JLS
JLS
Tacking the nuts to frame is a good idea. I like how the newest trucks come with u-nuts or captured nuts that clamp onto the frame which makes the process a one-man job.
However, I had my buddy help re-install the bed so since he was there he was able to tighten the bolts from the top and I could use a standard wrench from the bottom.
But, if a person is going for concourse-de-elegance' then that won't work...
Josh
I'd say a good specialty bolt and screw store should have some button "smooth" headed torx or allen style 1/2" bolts. I didn't check when I did mine. I just used grade 8 hex heads with flat washers, lock nuts with nylon inserts and anti sieze since I use a rubber mat anyway. They came off real easy with a friend up top with the air wrench and me under the bottom when I swapped chassis. Much easier then doing the offset grinder boogie like on the originals.
I use to go to Knoxville Bolt & Screw here in East TN to get specialty bolts for machines at work. Seems like they always had nearly any style, size and length you wanted. Might be worth looking around before settling for a dreaded carriage bolt that might just end up spinning on you for some good swearing affects.
These are the bed bolts for newer Super Duties... if I were to do mine over again I would go this route with the u-nuts on the frame. They are torx head bolts.
Josh
Yea, Their's them smooth headed torxer's. Good deal, I figured there was such an animal around close by. That would be a great way to go.
Josh, I really like the looks of your FE Dual Quad setup. Makes me think of the older Mercurys and such. Steve McQueen would be proud of you.
Sometimes I think of my 77 highboy as an F250 Lincoln by it having a 460 out of a 78 Lincoln aboard. Usually when I go to Advance or Autozone parts counter, to simplify things when they say what vehicle, I just say a 78 Lincoln Continenital.
I pretty much look up my part numbers at home before I go...
Josh
Oh man, don't get me started on that! Especially now, 1974 truck, with 90s alternator, 90s electric fan, 80s intermittent wiper switch, modern headlights with relays, late 70s duraspark, late 60s engine, early 70s tranny, early 60s carbs and intake YADDA YADDA YADDA....
Josh
Josh
And now my truck is a 77 F150 body on a 78 F250 frame with axles out of a 79 F350 and a 92 F250, a lincoln motor (actually my 460 might be out of a truck, its got the saginaw box?), and transfer cases out of who even knows what years (203/205 doubled)...
Front 1 ton ford brakes, rear 1 ton chevy brakes....
I'm so not forward to having to keep all this straight as I get everything together and doubtless will need lots of small pieces. And even worse a few years down the road as I'm maintaining it.
