aluminum pulleys
I'm not sure what you mean by "performance" steel pulleys, but if you mean stuff like a larger alternator pulley to reduce parasitic drag, then those are available through pretty much any Mustang parts place. Not a whole lot to be had performance-wise with pulleys anyway, and underdriving your water pump isn't usually a good idea with a truck, so it seems like stock is what you need.
if you have a v belt setup than good luck but if your using a serp kit from a later motor than you have lots of options. http://www.summitracing.com/search/D...?Ns=Rank%7cAsc
if you have a v belt setup than good luck but if your using a serp kit from a later motor than you have lots of options. Pulley Kits - SummitRacing.com
Big Skier
31
02-27-2019 07:21 AM
trotsky13
28
11-29-2009 07:04 PM
pipman76
09-05-2009 05:43 PM
