Code V0105
Old 05-31-2010, 04:52 AM
amsk8er1983's Avatar
amsk8er1983
amsk8er1983 is offline
Code V0105
So heres whats going on once in a while I will go to start the excursion and it will just crank and crank but not turn over. So I turn the key off and try again and turns over right away. So I go to my edge jucie attitude monitor and do a dtc code check and it brings up only one code V0105 (loss of communication to the FICM) It has been running fine no other problems it only does it once in a while. Should I be worried I am going on a 4000 mile road trip in six days. Is this a sign of my FICM going bad or my high pressure oil pump going bad or something wrong with the PCM? Can't be the egr system because I deleted it the only thing different I have done was switched to rotellat6 5w-40 but that shouldn't matter. Please help guys
Old 05-31-2010, 05:48 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
Code U0105: Loss of communication to the FICM--check for a wiring issue. Make sure your harnesses are all plugged in. Try removing the Edge box and see if it still happens. Nothing to indicate an HPOP problem.
Go to the FICM disgnostics in the 6.0 tech folder and go through those.
Go here for what the code can mean: 2005 Update Page 10 Diagnostic Codes P2199 thru U0306 By reading the code it can be PCM, FICM, or a circuit problem. The first thing I would check for is wiring and correct FICM voltage.
Old 06-01-2010, 05:56 AM
LostMedic's Avatar
LostMedic
LostMedic is offline
I've had one that did the same. The engine would stall with no warning but would restart without fuss. Check all the above and check your FICM and PCM relays and if they sit tightly as well. There's a complete procedure for U0105 in the Ford book.
bigbeariron
09-24-2020 07:49 PM
bismic
10-28-2017 05:10 AM
ToolmakerRob
05-20-2017 10:02 PM
ss72450
09-14-2016 04:34 PM
mkingz
12-16-2015 03:46 PM
Quick Reply: Code V0105
