Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
  #1 (permalink)
Old 02-08-2002, 11:36 PM
charlesvalentine charlesvalentine is offline
Garage is empty, add now
charlesvalentine is starting off with a positive reputation.
5.4L oil pan gasket change question
My 99 EB Expy has the famed oil pan gasket leak. I got a fel-pro gasket replacment and rolled under the truck to have a look see. I have not tried yet, but I am not sure that I will be able to get the oil pan off. There is a crossmember directly below it and it does not look like there is sufficient clearance to get the pan off. Has anyone here done this repair? Do I need to lift the engine up a few inches or will I be able to shimmy the pan off without unbolting the engine?
Also, any tips or tricks with doing this job on this vehicle would be appreciated. BTW this will be my first time to install an oil pan gasket that does not require RTV, so wish me luck!
__________________
02 e450 DRW v10 motorhome
  #2 (permalink)
Old 02-09-2002, 07:08 AM
legenddrug legenddrug is offline
legenddrug is starting off with a positive reputation.
Post 5.4L oil pan gasket change question
Tags
02, 2002, 2006, 250, 54, change, e450, expedition, f250, ford, gasket, oil, pan, replace, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
