Ford Part Number Cross Reference Guide??? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 05-30-2010, 07:26 PM
60RatRod's Avatar
60RatRod 60RatRod is offline
60RatRod has a good reputation on FTE.60RatRod has a good reputation on FTE.60RatRod has a good reputation on FTE.
Does anyone know of a Ford Part Number Cross Reference Guide for Ford P/N#'s? I was wondering because I have a P/N from an invoice from the PO and because of a recent discovery I am wondering if I have had an E99 or 99.5 part installed. The parts in question are my IDM and PCM. I was reading that there are voltage differances in the IDM's and not sure why the PCM was replaced. BTW it was done a local owned shop and not the dealer, I already tried to obtain an OASIS report.
Old 06-13-2010, 12:23 PM
60DRB's Avatar
60DRB 60DRB is offline
60DRB is gaining momentum as a positive member of FTE.60DRB is gaining momentum as a positive member of FTE.
yes, I also would like to know of a cross reference list. Even for little stuff like fuel filters...
Old 06-13-2010, 12:29 PM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
PREMIUM SPONSOR
Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.
You can also visually check and see what you have. If you find the PCM Code we can tell you if it is the Early 99 or not as well as the IDM.
Old 06-13-2010, 03:33 PM
60RatRod's Avatar
Quote:
Would AE give me that info? I need new Valve cover gaskets. Obviously, since I dicovered I have high temp RTV oozing out of my right valve cover. So I will have to buy those before I pull them and see which injectors I have, AD or AB. If I undertsand correctly those two are the E99 and late 99 injectors? I am just wondering if the PO matched everything up correctly. I have No idea why else the IDM and PCM would have had to be replaced.
Old 06-13-2010, 04:22 PM
big poppa's Avatar
big poppa big poppa is offline
big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.
Old 06-13-2010, 09:41 PM
60RatRod's Avatar
Mike, Thtas a great reference site thanks for sharing. REPS
Dan
Old 06-13-2010, 09:56 PM
big poppa's Avatar
Quote:
Dan
Your more than welcome, might not be exactly what your looking for, PCM compatibility wise but it is very useful. Thanks for the reps Dan..
Old 06-13-2010, 10:04 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
If AE will run a Cyliner Rotaional Velocity Test then you do not have an E99 PCM.
AD and AB injectors are both split shot type and an E99 or later PCM will work. As far as the Idms the E99 is a 110 Volt and the 9.5+ is a 120 Volt. Both can be modded to 140 Volts, but IMO it is not worth it if you get the right tunes.
Old 06-13-2010, 10:07 PM
60RatRod's Avatar
Thank you Robin, I appreciate the tips.
Dan
IDM or PCM? Place your bets! noober0x 1999 to 2016 Super Duty 0 09-13-2016 08:17 PM
Transmission cooler lines!!! 05SuperFord 1999 to 2016 Super Duty 10 04-03-2014 08:47 PM
99 Ford Diesel running rough broncobuster728 1999 to 2016 Super Duty 2 07-27-2013 06:18 PM
NVK4 PCM JonathanN WTB - Parts & other 0 09-15-2010 12:42 PM
IDM mod w/pics CPUNeck 1999 - 2003 7.3L Power Stroke Diesel 27 04-25-2010 09:10 PM
Tags
46, afe, cross, crossover, ford, idm, number, numbers, part, pcm, pn, reference, refrence, servce, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
