Battery Light on - Ford Truck Enthusiasts Forums
Battery Light on
Old 05-30-2010, 07:12 PM
jkiser01 jkiser01 is offline
jkiser01 is starting off with a positive reputation.
Battery Light on
I have an 06' F-350, 6.0 that is having electric issues. I put a new alternator on last week which seemed to fix the battery light but it only lasted 3 days & now the battery light is on again. I have had the alternator & batteries checked & they all checked ok. Anyone have any suggestions????
Old 05-30-2010, 07:17 PM
69cj's Avatar
69cj 69cj is online now
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
The batteries have to be checked totally iosolated from each other. If done the way they did mine at AZ, you didn't have a valid test.
Old 05-30-2010, 07:24 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
Batteries need to be:
A) removed from vehicle
B) charged fully
C) load tested separately with a realistic load similar to what a diesel starter imposes.
One major issue: Alternator wiring - pigtail and also battery / alternator connectors.
Check link below.
Test alternator output (voltage and current with a clamp on ammeter).
Give us data on voltage:
a) sitting still after 12 hrs no run / charge
b) key on, glow plug cycling
c) key on after 2 min
d) cranking
e) immediate voltage when engine catches
f) voltage at 30 sec intervals to 5 min after start.
It should be in the 14ish vote range then.
Old 05-30-2010, 08:20 PM
DPorter DPorter is online now
DPorter is gaining momentum as a positive member of FTE.
could be a bad alt out of the box.
Old 05-30-2010, 11:13 PM
I have the charger on the secondary battery tonight. I will check it in the morning while the primary battery is charging. I hit them with a load tester while hooked in circuit & they both tested bad so I will isolate them & check. I had the new alternator tested & it is good according to the tester. Thanks for the input.
Old 05-31-2010, 10:08 AM
69cj's Avatar
If only 1 battery tests bad, replace them both. If not the older one will drag down the new one.
Old 05-31-2010, 10:26 AM
Quote:
Roger that.
The older battery that is good is often fine for use in another car....
Mark:
If you are reading... the batteries that "dont test" for your truck is the perfect batteries for your inverter ---
free, and it is "good enough" for the job.
Old 05-31-2010, 11:29 AM
Replaced both batteries & the light stayed off for an hour & then back on. As I stated before, I had the alternator tested & now 2 new batteries but no cure yet. I guess it will head to the shop tomorrow to get a full diagnostics on it.
Old 05-31-2010, 11:35 AM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
***** Emeritus
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
Before you run off to the shop check all of the grounding wires/straps. You might get lucky
Old 05-31-2010, 12:18 PM
I am willing to bet you (if it is not something simple like the grounding strap, contacts).
It is the pigtail.
If the pigtail is good, the other guess: another bad alternator.
Old 05-31-2010, 02:16 PM
We tested the output of the new alternator & it is only putting out 11.5 volts. The old alternator when tested was acting funny & spiking weird. I have some corrosion on the trailer plug so I am wondering if that would cause this to short out. I have checked all the ground straps I could find & they were good & clean. The only conclussion I could come come up is the trailer plug.
Old 05-31-2010, 02:26 PM
spinge spinge is offline
spinge is starting off with a positive reputation.
I am guessing alternator is the problem, especially if it is only putting out 11.5 on the test stand. On my 7.3, I went through 4 of them in about 10 days (was ugly). Also be wary of the control wires going to the alternator, not just the large power wire, and make sure the mounting area is clean, as the unit grounds through the body of the alternator to the engine.
The corrosion in the trailer plug on the back should have no real effect on the alternator, as all of those circuits are protected by fuses. A short would simply blow the fuse.
Old 05-31-2010, 04:00 PM
There have been a rash of bad alternators (including brand new ones) from what I see as sub-standard components.
11.5V?
What is the test procedure? Was it on car?
If it is ---- suspect a bad pigtail.
Old 05-31-2010, 04:46 PM
It was tested on the truck with it running. The weird thing is that the light started coming on while I was acclerating & then it would go off when I would stop at a light or sign. This is driving me nuts trying to figure this thing out.
Old 05-31-2010, 05:22 PM
Have the alt tested where you bought it, off of the vehicle. If it tests OK, do like gearloose said and get a pigtail.
2013 battery light on 61 uni 2009 - 2014 F150 6 05-24-2016 01:30 PM
09 3.0 alternator overcharging artieb Escape & Escape Hybrid 3 01-25-2016 11:59 AM
Battery Light??? NYRider 6.4L Power Stroke Diesel 0 01-22-2013 03:55 AM
Battery light noel431 2004 - 2008 F150 3 04-18-2010 03:35 PM
Battery idiot light. fgilmore 1987 - 1996 F150 & Larger F-Series Trucks 6 07-05-2000 08:56 AM
Tags
2006, 2008, 73, 99, alternator, batteries, battery, diesel, f150, f250, ford, good, light, superduty, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
